Dimenstional Key in
  • Dimenstional Key in
    What is Dimensional keyin window, How can we get in. is it an atribute measure for go/no go , or can be used as variabl, and how,
    please,give me some info on this feature,
    Thank you in advance,
    A Disho
    It shows up like an input comment at executon time. From there you can set variables if you wish. If you want to do attribute I'd recommend an input or better yet a yes no comment.
    Craig
      Wow - I never thought of setting up my attribute inspections with PCDMIS. I have my current attribute inspections done at a seperate station using Datamyte.
        I like to use the Keyin for Plug and Feeler gauges when I do Gauge / Fixture certifications.
        sigpic GO LEAFS GO!!!
        Stay true to your friends, 'cause they'll save you in the end.
        -Sam Roberts
          I use them all the time for hole sizes, and hand checks (radius gages, etc...)
          kb
          RFS Means Really Fussy Stuff
            Here's how mine looks... Notice how my feature names coorrespond with what is checked. I have detailed notes so all operators know just exactly what to do...
            COMMENT/OPER,NO,BREAK OUT THE MICROMETERS TO CHECK ALL PINS
            ,START BY FINDING THE 2.3/3.7MM GO/NOGO FEELER GAGE
            ,MIC THE 2.3MM GO PORTION FIRST
            COMMENT/REPT,-----------------------------------------
            ,2.3MM GO FEELER PIN +/-0.02MM
            ,PROFILE 1.4MM
            DIM 2.3_FEELER= KEYED IN DIMENSION OUTPUT=BOTH
            M 2.300 0.020 0.020 2.286 -0.014 0.000 -#-------
            COMMENT/OPER,NO,MIC THE 3.7MM NOGO PORTION
            COMMENT/REPT,----------------------------------------------
            ,3.7MM NOGO FEELER PIN +/-0.02MM
            ,PROFILE 1.4MM
            DIM 3.7_FEELER= KEYED IN DIMENSION OUTPUT=BOTH
            M 3.700 0.020 0.020 3.688 -0.012 0.000 -#-------
