Printer switching it's self
  • Printer switching it's self
    At the end of the program when it comes time to print some how the program is switching from my default printer to the "PC DMIS 250 CONVERTER" and it makes it the default printer. Anyone had this happen to them and if so how did you make it stop doing this. V4.2 MR1
    Is there multiple print commands in your program? Be sure your printer that you want to use is set for default. Be sure your print settings are going to that default printer within PC-Dmis. JC
    Jeremy Cavender
    CMM Metrology Engineer
    PC-Dmis 3.2/2010/MR2
      It prints to the converter when you send your reports to a PDF file. Check and see if you have that box checked and not the actual print box.
        The program does not contain any print commands. I have the printing taking place from the "REPORT PRINT OPTION" window. And it's not just when it runs one certain program it does it with every run of any program for the last 3 days now. Never before that. The defaults are set set and reset.
          This a constant headache for us. And, it was doing it since version 4.0 (now at v4.2mr1). There are times we have to rebot to get it to generate a report. I'd like to know if there are any ideas on how to get it to stop.
            JOSH,
            Both are checked as always we send the info to the printer and the file and have for years.
              Settimg Editor
              Ignore Dimension Icon
              This value is used to resolve a problem that exists with some HP printer drivers where the
              dimension icon on the table is not implemented correctly. Set this value to TRUE (1) to avoid
              problems with these printers.
              Entry Name: IgnoreDimensionIcon
              Entry Type: Whole Number specifying TRUE (1) or FALSE (0). Default value is 0.
              User permission is required to change entry
              Printing
              This section of the PC-DMIS Settings Editor allows you to set parameters that are used for
              printing from PC-DMIS to printers of output files (RTF or PDF).
              It currently has the DoNotUseAmyuniRTF entry
              Do Not Use Amyuni RTF
              This value is used to determine if PC-DMIS will use the old-style RTF output rather than the
              Amyuni RTF output.
              Entry Name: DoNotUseAmyuniRTF
              Entry Type: Whole Number to specify RTF output option. Default value is (0).
              Output Option Key:
              0 RTF output uses Amyuni RTF output.
              1 RTF output uses the old style RTF if you have selected the RTF output option via the
              Report Print Options dialog box before the program was executed. Setting the
              PRINT/REPORT command to RTF will not work correctly for this value.
              2 RTF output uses the old style RTF even if you have not set the option to “Print to
              RTF” in the Report Print Setup dialog box before the program was executed. This is
              useful for the Blade program where the wrong control would be used for reporting
              resulting in nothing being output if the flag was set to 1. Under all conditions the
              correct text object is used to display text in the report window.
              THANKS (CAD IS ALWAYS MASTER)
