Everyone,
I have a program that I need to change slightly to be able to run a similar part. The biggest difference is diameter changes. Not to bad to deal with. The other difference is the location in one dimension (y) of some of the features. Now, I have changed on feature upon which I base an alignment to measure other features. I answered "No" to "do you want to update the nominals of affected features" or whatever it says.
So, I have a cylinder "master" that I align on and then measure different "slave" diameters associated with this cylinder. When I change the location of the "master" cylinder and answer "No" I expect the "slave" cylinders to still be at 0,0 relative to the "master" cylinder. They are not, they stay in the same place relative to the original alignment. I have done this before without troubles but it doesn't seem to work now. Is it because the "master" is an autofeature?
