I have currently encountered an error when calibrating sp25 probe, never before out of my 4 months experince with this probe. The problem starts of when at the start of measured (tip A0 B0) after the 5 hits, then starts the scanning algorithm. It scans the sphere normally, then comes to the end of the one direction, the unusual occurrs, it pauses for a good 7 minutes, then continues with the same ocurrance at other directions. At the end when the probe utilities window appears, it gives a window with "Renishaw algorithm failed to calculate calibration parameters. The reported error text is: OK, the the convergence criteria have not been reached."
Does anyone know what is going on with this unusual error in which I have executed before many times with no problems?
Thanks again gurus!
Thanks again gurus!
