Hi!
I'm scanning some surface to using SP25 (indifferently with module). In settings window scanning I set Cut Vector so as to one of the direct vector (i, j or k) had value "1", rest "0". When scanning is done I see one of the coordinate doesn't have this same values - dispersion is on level even 0.01mm . WHY???, if I put value "1" in one of the direct vector?
