Anyone using 4.0??
I use it at another job and would like to change the amount of tags that are viewed in the graphic window.
I right click on a ID tag in the graphic window and choose "show all" and I get a message that only 100 tags per view are allowed!! This is very restrictive when trying to find a feature graphically. I didn't write the program I am trying to edit and cant spend all night manually clicking on each feature (approx 600 features total)!!
Well with the message it gives one would assume that if you created multiple views it would put 1-100 in view 1, 101-200 in view 2, and so on.......this isn't the case....go figure!!
It shows the same or less tags from the first view in each of the other 4 views i set up.....aaaaaaaahhhhhhggggggg!!!!
Am I missing something??
I asked this at the usergroup and was told that the maximum is 400 tags. I was told it could be increased to 400. I'm not sure if he meant 400 total or 400 per view. Either way I don't know where or how to increase this value. I searched for every possible "string" in the settings editor and couldn't find any default value set to 100. I can only assume its not listed under something I would think it should be.
Anyone have any suggestions to increase the tags per view??
thanks
Mike
this was sent to tech sup last week wednesday.....no response yet.....can you guys beat there response time?
thanks
Mike
