I am looking for some examples of for coding that automatically adjusts the tolerence of a line to line distance to reflect the MMC deviation. What I am doing is measuring slots using 2 lines to obtain the size and a mid-line to obtain the location in the axis. The reason that I do not wish to use the autoslot is due to the fact that it does not measeure the side walls and only measures the radii on the ends of the slot. There is often time mismatch between the radii and the walls so I would like to keep measuring the walls for the most accurate representation of the location of the slot. Any examples would be appreciated. Thanks in advance.
Slots and features of size with true positioning
Change your round slot to a square slot and tick the width measure box. The instructor that used to be in Nashville taught me this and it works great. Just make sure you have a large enough radius that you are on the long walls. If you have 3.7 you can see where the points will end up. HTHsigpicYou're just jealous the voices talk to me.
Who was your instructor in Nashville?
Originally posted by DaddyBlutoChange your round slot to a square slot and tick the width measure box. The instructor that used to be in Nashville taught me this and it works great. Just make sure you have a large enough radius that you are on the long walls. If you have 3.7 you can see where the points will end up. HTHsigpic
PCDMIS 2012
Windows Office XP
TKsigpicHave a homebrew
Originally posted by DaddyBlutoRay Wilson. He has gone out on his own now. Good guy and very smart.
He seemed like an awesome guy. He's gone out on his own now? Programming or what?sigpic
PCDMIS 2012
Windows Office XP
Maybe someday the software engineers will make the autoslot measuring feature so that a slot can actually be measured correctly in regards to GD&T.
Most slots are TP referenced to a datum plane or perpendicular to that plane
not just in a 2D location. If dimensioned this way then there is a zonal perpendicularity requirement to that datum. Round slots are actually 2 cylinders & 2 planes intersecting tangently. Shorter round slots would have some difficulty measuring the 2 planar surfaces but the 2 cylindrical surfaces could always be measured. One might consider constructing a feature set including 2 cylinders & 2 points one on each side of the width to correctly report the 3D TP utilizing the cylindrical axes & the distance between the 2 side points. Also, machining is so high speed now days that machine programmers do not give tooling time to actually cut the radial ends at a decreased feedrate so tools push off slightly resulting in the radius ends to be considerably smaller than the actual slot width. It would also greatly depend on the slot tolerance to determine if a slot would actually need to be measured this closely or not. Most of the slots I measure do & it would be nice to have the software do most of the work for me by measuring the feature as stated above incorporating cylinders & points combined.
Tolerence changing
Originally posted by kmcmmCreating a generic circle front the lines is probably the best solution your problem, but you can also use variables to figure the MMC tolerance and input that into your dimension in the edit window.
Do you have any examples of the variable input/read for tolerence changing?
PC-DMIS limitations
In all actuality, I would perfectly happy if PC-DMIS would give an option to measure the walls and include those measurements in the overall construction of the autoslot. This would be ideal for the calculation of the MMC and the application of best fit true positioning to the datum structure without loosing any accuracy to the true form of the slot.
by virago111
My issue is, how do I allow for the MMC condition of the open ended slot. Currently I measure the two vertical lines.
By the way the...-
11-14-2012, 12:49 PM -
by csshafferI have a part with a slot cut in it and the print calls out a true position for it. I do not have a cad model so I guessing I need to make a constructed...
05-23-2011, 02:05 PM -
by Adam OlsonI have a slot or pocket whatever you want to call it which is datum -d-. My problem is that the slot is tapered (will attach a pic and print) and it does...
09-04-2008, 11:36 AM -
by MANIKANTAHow to check bidirectional position tolerance using xact measure....
08-20-2016, 01:22 PM -
Here's a new one (for me). I have a slot that needs to be toleranced with a true position. There are a few issues I need input and a solution for....
06-04-2010, 12:22 PM -
