I am curious what most of you do. When more than one styli is needed and multiple tip angles, do you probe all possible features with one stylus and then change styli and probe remaining. Or, do you switch back and forth between styli in one angle then move to other angles?
Styli/Angle Changes
Originally posted by Matthew D. HoedemanI don't. I will work to find a way to check the entire part with one set up. I do not have a changer and I am still using a PH9 and TP2's.
If I am doing blue-print feature measurement, I start by numbering the print, and then I follow the numbering scheme I have on the print. So when I need to switch tips and/or angles I do it where needed. I use an SP600 and have a total of 4 caps for it that I change out by hand(no changer). Same goes for my TP20.sigpic
I have a PH10MQ with tp2. If i need multiple tips i use a 5way and put the tips and angles i need. I try to write 1 program for the entire part without having to recalibrate.sigpic.....Its called golf because all the other 4 letter words were taken
I suppose I am a bit spoiled. I have a tp20 & a tp200 changer. So I have a total of 12 stylii at my disposal. I can not think of a program offhand that needs more than 3. I write programs both ways depending on the part and what has to be checked. I would say that most of the time I check each section/view from the print complete and change tips as needed. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
I guess I have always just done all the angles and then changed tips. I was just curious. The reason I do it my way is that I don't have a changer and so to continually switch is a big pain in the ***. If I do all of one stylus and then switch to another I can leave the machine to do it's (see if DaddyBluto catches that) thing and I don't have to keep switching the modules.
I have a TP200 & a SP600 w/ a PH10MQ. I have several modules and pucks for the TP200 & SP600, so I measure as much as I can w/ the 1st tip then change modules. I also have programs where I switch between the TP200 and the SP600 using the auto joints. No tool changer. Some of my programs there is no other way to measure other than using both the TP200 and the SP600 .PCDmis 3.5mr2 CAD++
by r_johnsonSo I'm wondering if there is a "procedure" or a "proper way" to change a stlyi without a probe changer?
My boss told...-
01-10-2011, 01:10 PM -
by White06REXHello All, is their a way to give each Tip Angle/ Styli Angle a Unique name? What i am trying to accomplish is i have a customer that would like me to...
09-11-2015, 12:38 PM -
by DeWain HodgeI'm having a problem with the calibration of one of my styli on our new ONE CMM. We have an TESASTAR-M probe head, SP25 scanning probe, FCR rack and...
12-29-2008, 05:28 PM -
by Ken8282I am looking to get a new styli with 4mm by 75mm carbon fiber stem. Having never used carbon fiber stems before. Is there any special care they need?
02-25-2013, 11:05 AM -
by Coy BuchananWhich do you prefer:
Carbon Stem Styli or Stainless Steel Styli?
And Why?-
07-13-2006, 01:46 PM -
