Ok guys here is what i have. I have 3 machines with 3.5 mr2 installed on them. I installed all 3 . I'am the administrator. 2 of the machines work fine, the other one will not let me save programs. I've already gone to exlore and unchecked the read only boxes. I've been to our IT guy and he says since it's a serialization error i should contact B&S. I figured before i do that i would let you guru's have a shot at it. Attached is what the screen tells me when i try to save.Thanks in advance
Serialization error
Positive.........I installed all 3 versions the same day.
I spoke with B&S and they said to try and rename the probe file. I tried and it still did not work. I guess i'll call them again.......I love mondayssigpic.....Its called golf because all the other 4 letter words were taken
I found a fix. If i log onto the machine as myself it gives me serialization errors. It will let me rename a program, but will not let me save it or delete it. If i log on as administrator it lets me do anything i want. I think this machine is in need of an exorcismsigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by craiger_nyXP
Yea XP............Come to think about it i did not have to reload the software till we got new PC's.............All with XP, but only 1 gives me a problem...go figure.sigpic.....Its called golf because all the other 4 letter words were taken
by MeglaHello!
How to remove PART NAME, REV NUMBER, SER.NUMBER, STATS COUNT from header in pc-dmis 3.25 mr2?
Tnx!-
04-23-2009, 05:49 AM -
by deasyseProblem I'm having is with the report header. I don't use marked sets in my programs, I mark everything. I build a menu structure and use labels to branch...
06-01-2007, 06:05 PM -
by kstadWhy does the header at the top of my page not update to the correct date time and ss#? They want all my readings stored when I run this one part number...
11-13-2008, 08:10 AM -
by MansukhHow can I modify header and footer? I want to put my co. name header for my report.
Thanks-
09-03-2009, 11:02 AM -
I'm trying to create a header i can edit in word.
4.3's headers turn to pics when saved as an rtf. file.
so,I moved the text box for the...-
04-03-2009, 11:17 AM -
