I think I am looking for something like a perimeter scan or a liniar open type scan that takes a sample hit for every point. It would be like a scan with edge points. Mabey Im missing something, but I really dont see an option of doing this. Barrel probes are not an option for this scan, so Im kinda stuck...Should I just take a bunch of edge points or is there an eaiser way?
Is there a way that I can scan a sheet metal trim line in PCDmis?
Originally posted by Lawrence HardtackeAs previously stated use Linearopen with edge points. Turn "select surfaces" on and pick your needed surfaces then uncheck "select surfaces". Set up parameters as you like them. Sometimes depending on your CAD you may have to do the scan in sections rather than one long scan.
by ginnbobi am doing a line scan and when it hits the stopping point, it keeps on going and won't stop. how can I fix this?
10-19-2020, 04:10 PM -
by panelbeater1Morning,
Ive noticed that when I do a linear open scan, the scan hits change when the part is run online .
for example, if I...-
06-20-2020, 06:17 AM -
by FlintstoneGood morning,
Is there a link, or perhaps some other source, that can help me get my scans to work? I'm sure I'm doing several things wrong....-
10-19-2020, 07:36 AM -
by Tomi530iGood morning all
I have a nooby question.
When I'm using auto feature I can change the measurement strategies to Adaptive Scan...-
02-08-2016, 07:19 AM -
by Ken379128Ok so my problem is a linear open scan is taking 6 hit along a surface but one of the hits is going inside a groove on the surface, causing the scan to...
12-04-2006, 10:24 AM -
