Form & Location Lineprofile No Basic Dim
  • Form & Location Lineprofile No Basic Dim
    I have a customer telling me I need to check form & location on a line profile that has no basic dimensions back to the datum. We have been reporting form only for the last 5 years and now it is an issue. How do I report form & location without a basic dimension for the location?
    DeWain Hodge
    Do you have the CAD??
    Brain- Pinky, are you pondering what I'm pondering?
    Pinky- I think so, but where will we find an open tattoo parlor at this time of night?
      No CAD.
      DeWain Hodge
        Unless you have nominal XYZIJK data for each point/touch, you can NOT do F&L unless you choose a master part to get teh data from. For that matter, I do not know how you were able to do FORM only either, it also requires XYZIJK nominals, but then it does a 'best fit' alignment to report form only.
          Form only is like flatness or straightness. Form and location is what you want but you need the nominals. You need to talk to your engineers and get that data from them.
            Well, what do you know about the part in question?
            Post a drawing?
            PC-DMIS CAD++ 2o22.1 SP4
              If you have no BASIC dimension, report you're measurement as REFERENCE ONLY!
              GD&T requires BASIC dimension.
              Ask for an engineering review to change the print and add a BASIC dimension.
                Post a drawing?
                Here is a rough sketch.
                The 17.2/16.8 is the intersection of the back ramp & the 0.5° ramp.
                DeWain Hodge
                  Trig out a few nominals. You have the angle and the nominal to the intersection of the the flat and the angled surface. Should be a piece of cake.
                  B & S Global Performance 7-10-7
                  PC DMIS CAD ++ V4.2 MR1
                  PH10MQ SP25M
                    +1
                    Are you lacking the length of the surface that carries the callout or did you (un)intentionally leave that out? You might need that, so look for it on the drawing.
                      +1
                      There is no length to the intersect on the print.
                      DeWain Hodge
                        You don't need the length. The intersection of the flat and the angled surface acts as the vertex of the 5 degree right triangle that you will use to calculate your nominals. Just set (scribe on the part if on the bench) a couple of arbitrary inspections points/lines, say at .050, .100, and .150 from the vertex. On the cmm, create the vertex using an instersection point from 2 surfaces. At 5 degrees and the incerements in my example, the trigged side opposite is .0044 at .050, subtract that from the 17.0 nominal to get a calculated nominal of 16.9956.
                        This is just an example. I don't know how wide the angled surface is, so spread out your arbitrary locations to cover most of the surface.
                        PH10MQ SP25M
                          I don't think it possible to get any more info from he's given us.
