Running 4.2Mr1, The Hexigon cal. tech has been here this week calibrating our CMMs and (it seems) when they leave, I have some type of software problem. Anyway, when I execute my programs from the edit window (normally the screen changes to the graphics display screen and I can view the probe measuring the part) ... now, the graphics display screen disappears and the tool bar is the only view on the screen. When the program is complete ... the graphics display returns and doesn't go back to the edit window. Any suggestions?? Is this one of the corrupt gbarstat.dat file things? Thanks
Losing Graphics Display Window
Originally posted by DOUG MORTON View PostRunning 4.2Mr1, The Hexigon cal. tech has been here this week calibrating our CMMs and (it seems) when they leave, I have some type of software problem. Anyway, when I execute my programs from the edit window (normally the screen changes to the graphics display screen and I can view the probe measuring the part) ... now, the graphics display screen disappears and the tool bar is the only view on the screen. When the program is complete ... the graphics display returns and doesn't go back to the edit window. Any suggestions?? Is this one of the corrupt gbarstat.dat file things? Thanks
You need to set up a windows layout the way you want it. Let me know if you need help with that.
Originally posted by mtalla View Postwhen running a program, pause it , and then go to view> and turn on the graphics window and then procede . Save when done. should fix it.
Originally posted by DOUG MORTON View PostThat worked ... now toolbar is re-arranged and "grayed"????? I'll pause again and put my toolbar back in-order. Thanks
Note that PC-DMIS remembers has two different states for your windows and toolbars:
1) During programming.
2) During execution.
This means windows and toolbars that were set up for your programming environment may not be the same during execution. Simply pause execution set things as you want them and resume. The next time you execute, PC-DMIS should remember what you have opened and where you positioned them.Jared Hess - Techwriter @ WAI
by bpenn2112Somehow the graphics display window is locked in full screen and will not allow me to minimize or drag a corner to reduce the size. I normally have the...
06-08-2020, 11:43 AM -
by MJBolster
I keep losing my Graphics display when I execute my program- not always at first but somehow I change something ignorently and I get the demons...
10-15-2007, 08:47 AM -
by A DishoI had Graphics display wnd & Edit window both in one screen on pc monitor,but now only on of these two comes on screen although when I go to view...
05-12-2006, 07:23 AM -
by Steven69I am running a Mitutoyo manual with PC-DMIS 4.1. Last week my boss updated the outlook software on the terminal I use to run the CMM. Before this update,...
08-22-2007, 06:04 PM -
by cvollmerWhen I do a DISPLAY/METAFILE (screen capture) all I get is a black box and no graphics, does anyone know why? I also get the same thing if I try printing...
02-13-2014, 06:55 AM -
