I'm looking into buying one of those software packages that takes the data from either pc-dmis or datapage and generates automatic reports, graphs, etc. Does anyone have any recommendations?
Reporting software
DIS seems to be a real good one...
I've seen several reports from the DIS software from one of our third-party sources. I really like the looks of the reports, but I do not know how easy they are to generate...sigpic
PCDMIS 2012
Windows Office XP
I used DIS at a previous position and it is easy to learn and use. Call Joel Shafer for info. His number is 269-649-0311.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Do have the url for that site? I'm not having any luck searching for it.Last edited by phil george; 06-09-2006, 01:12 PM.
Check out this...
http://www.3dcs.com/softGDM3D.html
It's called GDM-3D. I've used this in the past and was pretty impressed. It takes a little work initially to set up the reports, but once it's set, it's dump and print.sigpic GO LEAFS GO!!!
Stay true to your friends, 'cause they'll save you in the end.
-Sam Roberts
by Tim AdkinsonHi all,
We are looking for some reporting software that will take data from our 2 different
cmm machines (output in excel or txt format)...-
12-11-2010, 11:46 AM -
by JOHNNIELEGAWe currently use Datapage & DIS inspect 6.0 for reports PC-DMIS 3.5MR2. Anyone know what newer versions of PC-DMIS
will still support DIS 6.0...-
10-18-2012, 03:02 PM -
by cmm-measurerHey y'all? Question regarding DIS (Dimensional Reporting Software) and PC-DMIS. I have used these 2 softwares together for years. DIS uploads the PC-DMIS...
03-01-2010, 10:14 AM -
by gsciolaHello All:
My company ordered a new CMM, and purchased an add on that allows reporting to an AS9200 form. The problem is; no one here knows...-
06-08-2015, 03:04 PM -
by CookieThe other day we were running a some software for a microscope view on the same computer that has my PCDMIS on it.
The software locked...-
07-29-2010, 11:38 AM -
