I just noticed this today...If I have my machine speed set to 100%, as the CMM moves to a point in the X axis, it will pass it up & have to go back a bit because of the speed that the arm is moving at. Sometimes this gives me an X axis lag error. What do I need to look at to find the problem?
CMM overtravels in X axis...
We have a couple of older bridge type BNS's. I have seen this problem with one of our older machines, and what it is is the plastic gear that drives the x axis. It has either sustained a crash, or the gear is getting old(on our machine it was a crash). We tightened it up(it had come loose after the crash). And for now we are good to go. Luckily we get calibrated in June so the Tech will probably be asked to replace the plastic thingymajobby.sigpic
It might be getting dirty (drives and belts) or they might be getting loose. The drive system is also the break, if it is loose, it will go too far and have to back up, but it you get it too tight, it will bind.sigpic
Lag error means the machine has not reached it's destination in an alloted amount of time. The controller figures it should take x amount of time to reach its destination and if it does not it errors out with a lag error. It is for when there are no obstructions per say but does not get there when it should. Go with the advise of the guys that susspect the drive system, and naturally start with the cheapest solution. Is something rubbing, dirty etc anything that will physically slow it down but not neccesarrily stop it.
by TgouletUsing newer B&S Global. Intermmitently (usually when I'm in a hurry for dims.)comes up with error in the Y axis and shuts down the mach. The error...
05-09-2008, 11:16 AM -
by rebeldudeHas anyone ever had a Z axis lag error at start up and after the air getting turned on and the error disappearing, the machine prompts me to click okay...
07-05-2013, 09:44 AM -
by Jakep379We are getting ready for an upgrade to an older Sheffield Bridge CMM. Replacing jog box, controller, Head and going with a scanning probe. I got asked...
07-11-2019, 02:16 PM -
Hey Guys-any Of You Using A Sharpe32 Controller? We Are Wondering What The Acccelleration Setting Should Be For Said Controller. We Are Running It On...
07-24-2008, 08:16 AM -
by Jimmy Hirschnever seen this un' before ................... anyone ???
05-17-2013, 02:25 PM -
