Hey guys and gals I am wanting to make the cmm go to home after I run the program. Whats the comand for this that I can use? I used to do it all the time with the old hp basic stuff but never tryed it with pc dmis.
Going Home
You can do a ctrl m or use the print button on your jog box if it is set up to do move points. Thats if you are just wanting the machine to move out of the way of your part.sigpic.....Its called golf because all the other 4 letter words were taken
what I do when I want to go to home is I get the value of x,y,z at the home position before any alignments. and do a alignment recall of the startup alignment at the end of the program and put a move point that is near the home position. be carefull to have clearance from the part you might make a incremental move first and you will need the probe a A0B0 for this to work2013 MRI
B&S DEA Ghibli & Global
There is a way <outside> of pcdmis:
if you know a way to write it as a batch file it could be done as an external command
1. with pcdmis closed
2. open hyperterminal
3. hold down ctrl and type ECB
4. at the prompt type AUTZER
5. close hyperterminal
::EDIT::
John Kingston's method will get you there just as wellLast edited by Mike N.; 06-07-2006, 01:11 PM.sigpiccall me "Plum Crazy"....but you only go around once!
You can also simply put in a move point to your current alignment to clear whatever it is you are checking. I use fixtures 99% of the time and if the head is over the part, you can't remove the part without risking a hit on the probe. However, the fixture may not go back on the table in the same place the next time it is up, so I put in a move point roughly to the 'out-of-the-way' corner of the fixture, allowing me to remove the part and keeping the probe over the fixture base, so as long as the base is within the movement volume of the machine, it won't hit a limit.sigpic
by ErikirI'd like to program a move to get the probe way, way out of the way, and to have the probe move to that location regardless of where the part was placed...
04-24-2014, 06:16 PM -
by ricardo_G60Hello guys,
I need some help please.
I have two machines with diferent sizes.
They Run the same programs (that we have...-
11-27-2019, 01:37 PM -
by NMC_CMMMorning all,
I've got an issue with my PFX machine this morning. We had a power surge over the weekend and need to do a Machine Home....-
09-03-2013, 08:28 AM -
by TestedI have now made it over to our other plant and found that the CMM is going to the correct home location when it first starts homing BUT, as soon as it...
11-26-2007, 11:46 AM -
by Jrgunn5150I've been asked to write simple programs, that require no joystick input from the operators, (I'm new here, but apparently they've bought two probe heads...
12-14-2015, 12:01 PM -
