I have a question. When I calibrate my probe tips, I thought that A0,B0 should be the first one to calibrate. Then all the other angles will calibrate in order they show in the Probe window.
My question is this,
When I select a probe to calibrate(mainly one inperticular) it satrts off calibrateing in a different angle,A7.5B-150.
Does this affect my calibration results for all the other angles?
I only use that angle for about two parts that we run. I use the A0,B0 angle 95% of the time. Is there something I need to do to get it to calibrate the A0,B0 first or does it matter?
I have even started by just calibrating the A0,B0 angle then going in and telling it to calibrate all angles. Still nothing.
Thanks
Thanks
