Casting and measure
  • Casting and measure
    Dear all,
    I'm writing to ask you about an information.
    I've got a casting and I must measure some ID referring to three principal plane (A, B, C).
    In particular way I must measure some plane for the milling machining. For example: I've a real plane (to Xtheor.) (parallel to A) in which there are N points.
    In the report I want to evidence the max/min stiffness relative to the Xtheor. In this case I make an alignment with X-offset to Xtheor and I've (in the hits plane)
    the real coordinate, but I don't know how to print in the report the max/min value (for example in X direction) of the N points (of the real plane).
    Could you help me?
    ASSIGN/V1 = array(h1.x,h2.x,h3.x,h.4x)
    ASSIGN/V2 = MAX(v1)
    ASSIGN/v3 = array(h1.y,h2.y,h3.y,h4.y)
    ASSIGN/v4 = max(v3)
    then put V4 in a generic feature
      Many thanks.
      Nico
