Hi Folks,
This is my first post here since the new forum, so here goes.
ONE machine with 3.7mr2 PH10T / TP20
I have a slot created using a CAD igs model and auto round slot. All is well. Nominals are good and everything works just like it's supposed to.
My problem is in the True Position reporting. The drawing uses a feature control frame TP - A @ max B @rfs C @ max. When I just use no datums the report shows the correct slot location measured compared to the nominals with the alignment on the correct datums. When I check the "use datums" box and add the datums and modifiers it reports the slot location exactly at nominal. X = 0 and Y = 0. If I turn off the use datums it goes back to the correct measured value.
I've proved it out using known good parts and known out of tolerance parts.
Why can I not get it to use the datums and get the bonus???
I have other programs with this same condition that work well. What setting must I change????
Thanks in advance. Peter DeGoot
