The MS Access DB is not supported in V4.0 so there is no DBWizard. In prior versions, the DBWizard is used to create/delete/register an MS Access database to be connected (used) by pcdmis via ODBC.
I wish they would have asked me before they decided not to support it (MS Access DB) in v4.0.
It worked fairly well in 3.7 and it would record data without intervention throughout our looping programs instead of only at the end (if you remember) like the Excel Wizard.
I am trying to set up a Database so all my data can be dumped into on my programs and when I insert the command I get no Data source or when i setup a...
