Truncated cone
  • Truncated cone
    Good Evening.
    My problem is this.
    I have to measure the diameter of a truncated cone. I do not have much of the cone to measure. My idea was to measure two circles at different heights and construct a cone, measure a plane, intersect the plane with the cone, and get a diameter, easy eh? No. Can anybody tell me how I constuct the cone from the two measured circles? Blowing here!
    Bristol Citysigpic
    Home of the Reds
    Have you tried (if possible) to create the cone using three circles instead of two?
    PC-DMIS CAD++ 2o19 R1 SP11
      Depending on your accuracy needs and the angle of the cone you may be getting too much cosine error by measuring as two (or three) separate circles.
      If you measure it either as a 'Measured' or 'Auto' cone the compensation vectors for each hit are at least theoretically correct.
      Eric
        Measure several rows of vector points then construct a cone from those points.
        Contura Calypso 5.4
          or just measure it as several standard measured points and construct a best fit re-comp cone
            Thank You.
            That gave me a good answer, but..................
            Can I break out the XYZIJK's of an auto-circle and paste them as points?
            I once thought I heard of some scripting that did this??
            Virgil.
            Bristol Citysigpic
            Home of the Reds
              measuring circles to make a cone is NOT a workable solution, the probe comp for the circles will only be done in 2-D whereas the cone requires 3-D comp. You can get the angle that way, but NOT any correct sizes.
              Reference the attached picture. The GREEN lines indicate the actual cone. The BLUE lines indicate where the CENTER POINT of the probe will be when making touches on the surface of the cone (yes, all data STARTS from the center point of the ball). The HORIZONTAL RED line would be a circle measured on the cone and the two verticle red lines indicate where the COMP will be when applied when measuring the circle, as you can see, those red intersections are NOT on the actual cone surface.
                I'm not sure that was what he was asking Matthew...
                I think this is not related to the cone measurement, do you want just the xyzijk's of the individual points in an outo circle?
                If so you could you assignments/expression builder to access them (time consuming) of access them through script - but I don't have the code that you'd need to hand and don't have time to produce it.
                if you could be clearer in your question that would help.
                  OP was talking about measuring 2 circles and a plane, constructing a CONE with the circles, then constructing an intersection circle of the cone and plane to get a size. It will not work due to the probe comp of the circles, that was what my post was in reference to, the intersected diameter will not be right.
                    Yeah I know, was just saying I think he's moved on from that.
                    If so I guess he should start a new thread.
                      Well, he started it AFTER I went home, but still, the OP idea needed to be addressed before someone else said, "HEY, that sounds like a good way to do it!" A little prevention is worth a TON of re-work, knowwhatI'msaying?
                        I have moved on, albeit a little bit, I was just wondering how you can break out the hits in a auto-measured circle, or any other auto-feature. Pretty sure someone had a script to do this, maybe a year or two back this might have been. Crikey, don't time fly.....
                        Bristol Citysigpic
                        Home of the Reds
                          you can do it with code in a feature:
                          A1         =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
                                      THEO/M1.HIT[1].X,M1.HIT[1].Y,M1.HIT[1].Z,M1.HIT[1].I,M1.HIT[1].J,M1.HIT[1].K
                                      ACTL/6.477,68.275,-0.001,0,0,1
                                      TARG/M1.HIT[1].X,M1.HIT[1].Y,M1.HIT[1].Z,M1.HIT[1].I,M1.HIT[1].J,M1.HIT[1].K
                                      THEO_THICKNESS = 0,RECT,SNAP = YES,$
                                      AUTO MOVE = NO,DISTANCE = 150
                          This will take a point at the XYZ location of the FIRST hit of feature M1 and will use the IJK (vector) of that hit
                            This may work in 3.7 and below, I don't know.
                            I just tried it in PC-DMIS 4.3mr1 RC and it worked. I will assume that it will work in all versions below that.
                            (Matt enter comments here__________________________________)
                              [ATTACH]3319[/ATTACH]
                              I dont understand why using recomp wont ignore the original point vectors and calculate the cone correctly. I thought that was the whole purpose of recomp'ing points for newly constructed features.
