you said always use perpen to center line in TP check this out.
DIM LOC3= TRUE POSITION OF CIRCLE F5 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH FIT TO DATUMS=OFF DEV PERPEN CENTERLINE=ON DISPLAY=DIAMETER AX NOMINAL +TOL -TOL BONUS MEAS DEV OUTTOL X 0.8770 0.8770 0.0000 Y 0.0000 -0.0008 -0.0008 Z 0.8320 0.8325 0.0005 DF 0.5000 0.0100 0.0100 0.0102 0.4998 -0.0002 0.0000 ---#---- TP MMC 0.0200 0.0102 [COLOR="Red"]2.5766 [/COLOR] 2.5464 -------> END OF DIMENSION LOC3 DIM LOC3= TRUE POSITION OF CIRCLE F5 UNITS=IN ,$ GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH FIT TO DATUMS=OFF DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER AX NOMINAL +TOL -TOL BONUS MEAS DEV OUTTOL X 0.8770 0.8770 0.0000 Y 0.0000 -0.0008 -0.0008 Z 0.8320 0.8325 0.0005 DF 0.5000 0.0100 0.0100 0.0102 0.4998 -0.0002 0.0000 ---#---- TP MMC 0.0200 0.0102 [COLOR="red"]0.0019 [/COLOR] 0.0000 #------- END OF DIMENSION LOC3
