99.9% of our blueprints uses +/- tolerance to control feature locations. Now after running these part for 40 years, the engineers wants to convert to GD&T (70+ prints) which I have used on MM4 quite a bit, not much on PCDMIS. So I need a little help in understanding the TP callout icon. I have three datum I use to create an alignment that will check every feature on the part back to. So do I even need to use the Matrials Condition callout, trying to understand that is a little bit hard. Does any one have any litature or help on this. I'm using V3.7MR3. Also it says in the materials block use datums, do we have to assign a datum name to certain feature.???????
Thanks..
Thanks..
