I have a drawing for a part that is a metal tube with a hole cut straight thru the side of the tube. You end up with a sort of a "shark-bite" looking tube. Now, turning the tube over so that you are looking at it from the side, 90 deg perpendicular to the hole thru the side, you are left with an hourglass-shaped part. NOW...the hourglass-looking features have a profile callout. That's OK. What I don't get is all the basic dimensions defining where along the tube the hole is located, the 'angle' of the hourglass cutout etc. What tolerance do I use for the 90 degree angle of the cutout, the overall diameter, the starting-point location?
(The profile tol is .010")
Help! jpegs attached
I just read 2.12 of the Y14.5 1994, and it addresses this issue. I'm now wondering if I even need to worry about these callouts.??
