I can't remember if +dft means to measure at the largest end and -dft means to measure at the smallest end??
+ / - Draft
Plus draft means material is added to achieve draft. A demension measured +draft is taken farthest from the parting line - @ least material condition. (Smallest boss, largest hole.)v2013 MR1, v2015.1
B&S Global 544, 555
Mitutoyo A504 w/PC-DMIS
Since 1994
(Advice from my dad.)
So...
+ draft in a hole means the dimension gets bigger towards the other end.
- draft in a hole means the dimension gets smaller towards the other end.
And...
+ draft on a stud means the dimension gets bigger towards the other end.
- draft on a stud means the dimension gets smaller towards the other end.I used to be high on life but I built up a tolerance.
To restate:
Plus draft adds material as you move toward the parting line.
Minus draft removes material as you move away from the parting line.
Minus draft measurements are made closest to the P/L, plus draft are farthest from P/L.v2013 MR1, v2015.1
B&S Global 544, 555
Since 1994
by AlexAI want to be able to load a part on a fixture either way up, and the program select the correct cycle based on whether a hole is or isn't present....
05-24-2012, 06:11 AM -
by CaemgenOk, I have to check a part as shown in the pic.
The start of the hole is at the arrowhead with a position of .014 applied to it.
02-24-2014, 02:51 PM -
by supahonkeyI am new to PC-DMIS. I've been trained with Zeiss Calypso and a lot of stuff is different! I have a few holes in a part that I am trying to get the...
12-23-2010, 10:01 AM -
by RCloneI am in the middle of a GD&T class.
The instructor shows a square with 5 holes in a line and a dimension of 85 plus or minus 1mm between each...-
05-05-2008, 10:57 PM -
by scharschI wrote a program with an imported IGS model. I did the manual 3-2-1 alignment and CAD=part. When I run in DCC mode and measure a hole feature, it either...
12-21-2007, 11:46 PM -
