In relation to my post a few posts down........Rob Knoerlein-circular part with 8 legs.. If I am rotated 90/135 and tracking to hit a feature ( in this case a leg), that is at approximately 2:00 , would not my vector be -.7071,-.7071,0 ? The whole part is programmed in z plus but I thought vectors are directionals of the probe coming off the feature???? This is what they taught at training???The probe is tracking towards the leg but seems take to point at the last minute by sweeping left to right and not just taking it head on. Someone suggested my workplane was incorrect but I have always pretty much stayed in Zplus when working with large diameter rings. I admit I usually am using cad and the machine picks the vectors, but Im still unsure why changing these do not get me good hits???
vector question
If you are taking a circle from the z+ work plane the the circle vector will be 0,0,1 z+
The points it is takeing around the circle to get that center location will each have different vectors. the angle of the tip will not change the approach vectors to those points. The vector for the tip only helps define the angle and direction of the tip and nothing more. I hope I said this so you understand it.sigpichttp://npmichaels.com/ (My sons book)
THANKS (CAD IS ALWAYS MASTER)
Originally posted by Rob Knoerlein View PostIn relation to my post a few posts down........Rob Knoerlein-circular part with 8 legs.. If I am rotated 90/135 and tracking to hit a feature ( in this case a leg), that is at approximately 2:00 , would not my vector be -.7071,-.7071,0 ? The whole part is programmed in z plus but I thought vectors are directionals of the probe coming off the feature???? This is what they taught at training???The probe is tracking towards the leg but seems take to point at the last minute by sweeping left to right and not just taking it head on. Someone suggested my workplane was incorrect but I have always pretty much stayed in Zplus when working with large diameter rings. I admit I usually am using cad and the machine picks the vectors, but Im still unsure why changing these do not get me good hits???sigpic
The vector for the hits at the 45's should be 0.7071... each. The sign should be negative for both when the hit is halfway between X+ and Y+.
So yes, your vectors are correct (as long as this is an ID)
No. Rotate +45 degrees from Y+ (1:30/2:00 o'clock) would be +.7071,+.7071,0. Vectors always point away from the surface.
Comments anyoneB & S Global Performance 7-10-7
PC DMIS CAD ++ V4.2 MR1
PH10MQ SP25M
And yes, I am going completely insane. What I ended up doing yesterday was to simply clock the part 1/8 a turn so the hits checked the other four legs straight on. I was able to get the part out the door on time and felt comfortable with it, but while lying in bed last night, the reality that I almost had the guys skim .010 off the inner diameter of a $40,000 dollar part made me almost throw up. No wonder I have sleep apnea. I am going to work on this today time permitting as I really need to get it for future jobs. Im wondering now if this circular tracking probe vector stuff is not what was causing all the trouble I had sometime back with wacked out TP measures using polar angle and polar radius to calculate???
Originally posted by JamesMannes View PostAre you using learned hits vs auto-vector points? If so, then what you are seeing is why most people don't use measured hits. If you try to vector in ona surface other than a straight on vector, DMIS interprets your hit as straight on. Try the same thing with an auto-vector point and se what happens.sigpichttp://npmichaels.com/ (My sons book)
Originally posted by djayne View Postthere's No Bug - Your Point Vector Directions Are According To Your Part Alignment. The Only Way Your Vectors Should Be .7071 Is If You Are Taking A Point 45° To One Of Your Datum Planes.sigpichttp://npmichaels.com/ (My sons book)
Originally posted by Rob Knoerlein View Post4.2..................................could This Possibly Be The Answer??????????????
If I'm not wrong, the PAng/PRad TP bug affected features not measured while in Z+ workplane. If the features you have are measured in Z+, then you should check your alignment again, to see that it is correct.
But then again, this might not be related either...PC-DMIS CAD++ 2o22.2 SP2
I am working in the X-plus plane....and have these lovely holes in my part that are at goofy angles to the work plane.
I have one at a vector of...-
04-06-2006, 03:17 PM -
by BrandnewHi everyone,
We have a part that isn’t fully cleaning up after machining, due to forging (this is a circular part). i need to get...-
10-05-2010, 03:18 PM -
by Ken8282I have three questions on this.
We are measuring a gauge point on a conical surface to get a distance between two points. When you take a...-
12-08-2017, 07:37 AM -
Any of you guys aware of any vector tutorials to be found here?
07-09-2008, 01:58 PM -
by Mike_BI know my CMM can calculate vectors using 3 points, forming a plane, etc.
I also know how to extract the vector using "read machine"...-
08-19-2015, 04:09 PM -
