So what exactly are REF dimensions? Are they BASIC dimensions? I do not see any other dimensions that would reference these dimensions. What do you guys usually put on a FAIR for these dimensions?
REF dimensions
As far as I am concerned, are REF dimension is a "do-nothing" dimension. It is for reference only, not for serious inspection. So for what you will have to do about it, if someone is requiring you to report it, I would only report the ACTUAL, no tolerance, nothing else, just the measured value.sigpic
Ref (or reference) dimensions are exactly that. They are for refeing to when manufacturing the part. If all other dimensions are held to nominal (and the engineer did his math correctly) the ref dimension will be right on. They are also used to show a dimension that may be toleranced elsewhere on the print. It can help the person reading the drawing to understand a section view better. I don't balloon reference dimensions.
I have never balooned a Referance dimension & have never had a customer call back wanting them measured. as far as I'm concerned they are there for
tooling and exactly what they say they are for referance only, not to be toleranced.sigpicTHE TASK AHEAD OF YOU, IS NEVER AS GREAT AS THE POWER BEHIND YOU. I Fight for Freedom and Pray For Peace..
by Max TastyHi all,
Is there a way to cut and paste all the dimensions in a report and put them at the end? I've inherited a lot of programs with dimensions...-
04-13-2018, 11:04 AM -
by metalquest1I did a quick search for this topic and didn't come up with any results, so figured I'd post and see what I can find. Is there a way to report a feature...
03-28-2019, 04:45 PM -
I have reported two dimensions ( DIST A & DIST B). I need to subtract the DIST A measurement from the DIST B measurement and report the difference....
06-25-2015, 01:30 PM -
by nmalavskyCan anyone help me out. I want to be able to have PCDMIS automatically create a dimension after measuring a feature. As an example, I measure a vector...
10-12-2010, 04:23 PM -
by DAN_MMy company has two types of dimensions I need to report. MIS and IMS. They're literally the same features from the same alignments, just different tolerances...
06-11-2020, 10:01 AM -
