decimal places in report
  • decimal places in report
    I'll start my own report thread and quit butting in on others. How do I change my decimal places from 4 to 3 on my report?
    Hit f5 change it and the report should show the same
      Correct. That is the Hot Key.
      Using the tool bar, its Edit,Preferences,Setup,Dimension
        ****it I thought I already had it set to that! Thanks.
          FYI: due to rounding, if you reduce the decimal places, you can sometimes get a reported value showing at the limit of the tolerance but the report will show the dimension colored red, indicating out-of-tolerance.
          Lately, it occurs to me
          2017 R1 (Offline programming)
            Yeah, I've had that problem a lot. Just gotta back up and keep checking it until it comes in.
              Why do it the HARD WAY?
              3-place inch dimensions, +/-0.005" tolerance, use
              +/- 0.00544444444444449 for the tolerances, it will ONLY show as 0.005" in the report, but will hide those pesky out-by-tenths points. It will only show those OUT that round to the point where they show out. Geeez!
                I'll remember that. Thanks Matt.
                  Or just open it up in Word and change the color
                    Yeah, but don't you still get the little < or > in the report? You would have to TYPE something then, AND that method don't work so well with V4+ (which has even worse reporting than all the previous version combined!).
                      Or Edit Dimension Color
                        Put this in your program:
                        DISPLAYPRECISION/3
                        Jan.
                          Let's get this straight - the TOOLBAR is something totally different than the MENUS.
                          So using the MENU, it is Edit,Preferences,Setup,Dimension
                          PC-DMIS CAD++ 2o19 R1 SP11
                            Screw all of it, simple put your cursor above the FIRST dimension, hit ENTER, then type in DISPLAY and it will fill in, then choose the number of decimals you want. So, quit whining you two or NO ICE CREAM after supper!
                              Actually You have to type DISPLAYP before it will spell it out for you.
