does anybody know if it is possible to default snap point to no in version 3.7. we are using a manual machine and need it turned off permanently
snap point in version 3.7
Default to Snap
Hi Guys,
I believe that is controlled in the settings editor, under DMISUseSnap. Setting to 1 should default to snap on features. Using anything else in the settings will default to not use the Snap feature. Be careful when using the snap feature because it is not a 3D point that can be used for construction or actual feature location, it should only be used for analysis of deviation projected along the theoretical vector of a feature.
Hope this helps?Last edited by mchough1; 05-31-2006, 01:10 PM.Job Function:
Quality Engineer/Programmer
Machine Type:
Global
Software Version:
V2010 MR1
CMM Experience:
25+ yrs.
Could someone please explain what the "SNAP" feature under measurement properties in the Auto Feature dialgog box means and when it would be...
06-18-2015, 05:48 PM -
by inspector212I had some odd deviations of a few points in a program. The points were reporting "T" values. Two points within 10mm of each other were reporting...
10-23-2007, 12:30 PM -
by ricfreHas anyone experienced creating a program in 4.1 or sooner that when you bring it up in 4.2 and run it, if it will run, that it gives you bad true positions...
02-20-2008, 01:11 PM -
by RobertoWhat's up amigos!!!
I have received a program from our supplier.
Basically is a program that checks a few form and location...-
04-04-2008, 03:25 PM -
Good Afternoon,
Would someone be able to explain why / when the snap point function should / should not be used?
Thank you...-
06-08-2016, 02:53 PM -
