point/feature transparency CAD
  • point/feature transparency CAD
    how do you toggle this on and off? for 3.5MR2
    EDIT: when you are using points as spheres and you can see the points thru the cad model but they are grayed out (the ones that are inside the model).
    Try your view -setup window. "show lines over surface" check or un check this box. Hope its what you need.
    BS
    Windows 7
    Pc-Dmis 2015
    Global Performance 7-10-7
      exactly what i was looking for - thnx
      they pigeon hole stuff all over the place in this sw, like the show points as spheres option, what a pain it is to have to open the setttings editor to change the size of the points. why not just make it a setting in the main sw, and maybe organize things a little better like have all cad options under cad options and all graphics options under graphics options and all printing options under printing options.
      EDIT: all view options under view options, all edit window options under edit window options.............
      • RCW52
        viewing 'Edit window colours'
        by RCW52
        why is it that on my set-up under 'edit/preferences' the 'edit window colours' is 'greyed out' ?
        & how do i get it 'un-greyed'...
        11-03-2009, 10:48 AM
      • Jignesh
        Edit window disappear.
        by Jignesh
        I am running one program and only graphics window I can see on screen in execution. Could one of you tell me how it would be possible to see both edit...
        12-02-2016, 07:26 AM
      • dgibbons
        CAD point sizes
        by dgibbons
        Does anyone know if there is a way to change the size of the points created in the CAD view.
        Sometimes the points are a bit big and hide other...
        06-17-2013, 09:07 AM
      • bigjosh
        problems with CAD
        by bigjosh
        I'm having a issue with the CAD , It's a step file and when imported it has incomplete/missing surfaces. I know in other software there is a way to "heal"...
        07-01-2013, 09:52 AM
      • venkat9
        Cad Levels
        by venkat9
        How to create Levels in View set up window??? For no of cad models in one program?? I tried much using with help file..But I cannot..Can any one suggest...
        09-07-2012, 06:05 AM
