changing cad model orientation
  • changing cad model orientation
    I have a cad model that I have imported into my Pc-Dmis program.
    Someone has saved the model set at an odd angle.
    when I do my alignment and hit cad=part button the model will not
    sit flat with the leveling plane. Is there a way to figure out at what angle the model is set at so i can rotate the model to print?
    4.2 MR1
    I got all the sweet hook-ups. Know what I mean Vern.
    pc-dmis version 4.3
    Do a plane on top of the model with program mode. (ctrl+F4). Then evaluate the angle between that plane and the Z axis.
      Go to operations tab...then Graphics display window.....then transform...This allows you to rotate your CAD model to what ever you want.
      http://www.pcdmisforum.com/signature...gpic5172_4.gifExel 9-12-9 4.3 cad++
        never knew that ?
        thanks. yet again another good reason for having this site.
        sigpicRichie the Villian!!
        V4.2 MR1 CAD++/MISTRAL 10-07-07 DCC/XP
          After he figures out what the angle is of course.
            ctrl and f1 will place it in Translate mode
            Hold down Ctrl and right mouse button with arrow on cad model and you can turn it any way you want. By moving the mouse around.
            THANKS (CAD IS ALWAYS MASTER)
              thank you
              pc-dmis version 4.3
                I assume that's in newer versions than 3.5mr2??? I don't see a transform or translate option.
                Jonathan S
                pcdmis 2009
                G&L CORDAX RS-150 DCC
                B&S global 15-30-10
                DEA Delta Slant 30-100-15
                  Never had 3.5...sorry..we went from 3.2 to 4.2 !!!
