I just got done 'editing' a customer supplied program to actually run on my machine (it would not have run on ANY machine) and they used the AUTOMOVE for absolutely EVERY check point in the program. AND, they used a value equal to the PREHIT/RETRACT values they had in the program.
THIS DOES NOTHING BUT WASTE TIME!!!!
If your automove value for anything other than a hole-type feature is equal to or less than your probe radius + your prehit, then all you are doing is making the machine go back and forth without doing you any good. It will move to a position equal to the automove from the center of the ball to the touch locaiton. Then, it will move to the prehit position which is the prehit value of SPACE between the tip and the touch, then it moves to the touch, then retracts so that the SPACE between the tip and the touch is equal to the retract, then it will move the end automove so that the center of the tip is the automove distance away from the touch. So, if the automove is equal or less than the prehit/retract + the probe radius, you are wasting MY time as well as yours.
SORRY, I doubt that these 'people' who made this program read this forum, but maybe it will help some of you out there as well.
