Can anyone tell me what the formula is for True Position? For whatever reason this engineer thinks that the true position should have a bilateral tolerance. ( print calls out true position of 12) The engineer thinks that it should be like a profile point and be +/- 6.
True position Formula
Originally posted by Shelia Moser View PostCan anyone tell me what the formula is for True Position? For whatever reason this engineer thinks that the true position should have a bilateral tolerance. ( print calls out true position of 12) The engineer thinks that it should be like a profile point and be +/- 6.
Well is it a Diametrical True position? Then no, if it does not have a Diametrical symbol then yes it is plus or minus 6.
x(dev)^2+y(dev)^2+z(dev)^2
(x(dev)*x(vector))^2+(y(dev)*y(vector))^2+(z(dev)* z(vector)^2)sigpicSummer Time. Gotta Love it!
Originally posted by John Kingston View PostsigpicSummer Time. Gotta Love it!
Originally posted by Paul Sarrach View PostWell is it a Diametrical True position? Then no, if it does not have a Diametrical symbol then yes it is plus or minus 6.
SQRT(x(dev)^2+y(dev)^2+z(dev)^2 )
SQRT((x(dev)*x(vector))^2+(y(dev)*y(vector))^2+(z(dev)* z(vector)^2))
FIFY, forgot the square root.When in doubt, post code. A second set of eyes might see something you missed.
He's half right. In your case the TP would be a circle with a 6 radius centered at the theoretical center of you feature, per your print. So if your x dim is 100 and you y dim is 100 then you TP circle center would be at x 100 and y 100.
And the center line of your feature would then have to be inside the circleAchieving unverifiable productivity daily
I like Phil's description. Draw a 6 inch radius circle. Draw a 12 x 12 square using the same center. The square represents a +/- 6 inch tolerance zone. The circle is the 6 inch TP zone. See how much of the square falls out of that zone? Show the engineer.When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by John Riggins View Post(squarerootofxdeviationsquaredplusydeviationcripes iwishtheywouldputtheignoreuseroptionbackineffecton thisforum)
edit:theydidifixthatoptionjohnLast edited by John Kingston; 06-12-2008, 08:25 PM.When in doubt, post code. A second set of eyes might see something you missed.
Originally posted by John Riggins View Posticantseemtofindtheignoreuserfeaturewhereisitexactl y?When in doubt, post code. A second set of eyes might see something you missed.
Maybe you need to talk to this kind of engineer:
http://i203.photobucket.com/albums/a...ock/rae2-a.jpg
Not this kind:
http://i203.photobucket.com/albums/a...n_engineer.jpgMarty Dobson
Director of Quality
http://www.linkedin.com/in/mjdobson
PC-DMIS CAD V4.2 MR1 & V2011
PH10MQ
TP200
by JigneshI started using legacy dimension when Translation to z=o is not set at Datum-A where holes are located to find true posion of four holes mean true position...
02-26-2016, 10:36 PM -
by jamesjr57Could someone please help me with the best way to define true position versus concentricity? I know the difference but when explaining it to my toolmakers,...
07-22-2009, 05:28 PM -
by j.gonzalezso i have a sketch of what im doing i need to find true position in x direction from my datum(1.849 dia) need help keeps giving bad numbers checking manually...
06-04-2009, 07:43 PM -
by Bob PierceIs it legitimate to dimension true position to a feature set?
I have a print where the true position call out is to 3 adjacent sides of a cube...-
04-26-2007, 01:12 PM -
