Printing in 4.2
  • Printing in 4.2
    I just installed 4.2 mr1 on my machine. When I went to print my results, it said no edit output selected. It seems like I ran into this before. Don't remember what I did to fix it. I know I can go under file/printing/report window print setup...and check the box, but that will make it print all the time. Don't want to do that. Any help here?
    Under file printing select nothing. At then end of your program add a print command into your program inside an if end if loop. Have a comment/oper input and if it equates to yes execute the print command
    Thats should work for ya
      I know of this method to. But, say I'm just checking a couple features and not wanting to save it as a program. Then what?
        It don't take that much time to file/printing/report window print setup.check print
        What 2 sec.
        THANKS (CAD IS ALWAYS MASTER)
          What 2 sec.
          No....It doesn't. But I didn't have to do this in 3.7. And I was just curious if something changed or I am just missing something.
            Ok...so I just fired 3.7 mr4 back up. I looked under printer setup and the print box WASN'T checked nor was there a print option at the end of the program. I clicked the print icon and my report printed successfully....So that goes to show that there is a setting somewhere that allows you to do this!!! grrr!!!
              I like the idea of adding am if/goto for printing reports. Thanks for that one.
              CMM Programmer
              Jackson Michigan
              Mistral 7.7.5
              4.3MR2
