importing CAD models?
  • importing CAD models?
    could anyone tell me the best files to use when importing?
    i started using 'iges' files at first(as told by B&S) but of late been using 'step' files,as they are much smaller in comparison.
    don't have aproblem with either but it would be interesting to see what other users prefer.
    sigpicRichie the Villian!!
    V4.2 MR1 CAD++/MISTRAL 10-07-07 DCC/XP
    iges seems to import quicker, but there seem to be less translation errors in the step files I get, so I try to work in step.
      I have used both. In the past(7 yrs ago) IGES was what was used, but there was a few times that things went goofy. So, by that, today with the latest and greatest version I prefer .STP files. This is just my preference.
      mike
      G&L 1808-M DCC MEA 4.3
      Endeavor to Persevere
        Step, usually cleaner
        3.7 MR4
          I use .step214 files. I've used .iges before, but the .step files seem to be more 'robust'....
          I like to use the SW dci I have, but it's too slow and the cad fixturing blows out everytime I use a SW model.
          Aaron Fenner
          Quality Engineer
          PC-Dmis v4.3
          B & S Global Status 7.7.7
          6 years xp 32-bit
            I use the step files. I asked the same question some time back because I had so much trouble trying to import iges files. Never did get the straight iges import to work, had to use the iges alternate & then I had some surfaces missing.
            I asked our engineering staff about it & they wanted me to use iges because with step files you "can loose some of the nominal info". Now I double check my nominals when I work on a program because they never could get me an iges file that would cleanly import.
            PC-DMIS v4.3 (as of 6/11/08)
            Cordax RS220
            PH10MQ
            SCR200/TP200
              I used step one time It worked ok. I use Iges all the time. If it does not import good in the normal iges, I will use alternate iges. Not to many problems.
              THANKS (CAD IS ALWAYS MASTER)
                Same here.
                PC-DMIS CAD++ 2o19 R1 SP11
                  Step files here. One of the biggest errors that we find is when someone converts to a step file is they do it in the wrong unit of measure. ie., a file that should have been Metric converted as inches. Iges files suck! missing surfaces etc.!
                  Cold Beer MMMmmmm........
                  Dell Precision T5400
                  Windows 7
                  B&S XCEL
                  WENZEL LH1512
                  PCDMIS 2011 MR1
                    I like Iges. I like wire frame for my circles, and I seem to get a rounder number that does not have to be edited for dimensioning
                      I almost always use step....iges has to many problems with surfaces missing and or can't click on them. Step can have issues also but they are much fewer.
                      If you are using one package ie. Unigraphics you can get the iges flavour(settings) that work for you and always export it as the default.
                      cheers
                      ________________________
                      DEA SCIROCCO-15-10-09
                      TUTOR P -4.2 MR1-XP
                        Lately, I have been translating the original cad file (usually Catia V5) to .igs and .stp.
                        The .igs as wireframe and the .stp as solid.
                        Then I import both (with merge) into PCD.
                        Lately, it occurs to me
                        2017 R1 (Offline programming)
                          can you tell me why you would you want to use a 'wire frame' instead of 'solid' ? as i've always used 'solid' ?
                          (whether it be iges or step)
                            Same here!
                            "I have a theory that the truth is never told during the nine-to-five hours."- Hunter S. Thompson
                              With the merged wireframe and solid you can complete some autofeatures with 1 click. It also makes it easier to see tangent lines.
                              • why me
                                Importing Models PcDMIS
                                by why me
                                which format do you guys have the least amount of trouble with I usually can get my Models in IGES or STEP Formats. I was wondering which is best ...
                                05-18-2007, 11:00 AM
                              • Willy T
                                Which Import Format?
                                by Willy T
                                Guess I need to import CAD models for PC-DMIS to make it easier on me.
                                The last attempt was IGES - our PC couldn't do the straight IGES,...
                                03-18-2008, 12:55 PM
                              • sandypacific
                                Importing UG models
                                by sandypacific
                                I am using an older version of PC-DMIS (4.2), and when importing UG (NX6) models I'm having difficulties with the models.
                                1. Some models...
                                09-17-2014, 01:17 PM
                              • Matthew D. Hoedeman
                                Step Files
                                by Matthew D. Hoedeman
                                Any of you know the difference between STEP-AP203 and STEP-AP214 files? I got a file from a customer (IGES) that Pcdmis would NOT import, it would get...
                                10-09-2006, 02:02 PM
                              • ProbFlex
                                Iges vs step cads
                                by ProbFlex
                                I understand that STEP AND IGES are two different types of cad software. But how does it effect or make a difference when using it in PC-DMIS?
                                11-01-2020, 02:05 PM
