What does pass thru plane mean ?
Need an explanation of pass thru plane
Tags: None
In setting the clear plane, It is the plane your probe will pass through to get to the next feature plane.
Working Plane: The Active and Pass Through Planes define the working plane.
Pcdmis will allow you to indicate the specific plane into which a feature
is projected when it is measured. The term 'working' is the same as
'current' or 'active' when referring to the working plane.sigpichttp://npmichaels.com/ (My sons book)
THANKS (CAD IS ALWAYS MASTER)
4.3 & 4.2MR2/GLOBAL/PH10MQ/WINDOWS XPComment
by mrnonameHi,
I was wondering if anyone could tell me how PC-DMIS views a plane to plane dimension. What my boss would like to know is when you level and...-
10-24-2008, 12:14 PM -
by SAmericaI'm measuring a block that should be ground almost true. I took one plane on one area of the ground surface (We'll call this plane A). Then I measured...
10-16-2013, 08:01 PM -
by Steve RHi all can someone explain how pass-through clearance plane works?
11-04-2016, 08:18 PM -
Currently am running PC-DMIS CAD++ 2016.0. I have probed a plane but would like to construct a plane based on the high points; as if it was sitting on...
03-19-2019, 09:32 PM -
by tnguyenGood morning. I am confused about working plane. My question is set up working plane by the machine 's axis or X,Y,Z from Cad model ?
Thanks in...-
03-27-2006, 06:27 AM -
