Generic Line
  • Generic Line
    How do you construct a generic line using the actual radius of a measured circle?
    Sorry! there was somebody here tabbed on my shoulder from behind I accidently hit summit thread before I add more details.
    Here goes.
    I have circle normal vector is 0,0,1
    and I want to construct a generic line normal vector 0,0,1 position of the generic line is
    (circle/2 on X plus side),0,0
    I don't have an application for this right now, just in case.
    This is for a line constructed from the radius with he line in the +X direction
    CIR1       =AUTO/CIRCLE,SHOWALLPARAMS = YES,SHOWHITS = NO
                THEO/0,0,0,0,0,1,0.75
                ACTL/0,0,0,0,0,1,0.75
                TARG/0,0,0,0,0,1
                THEO_THICKNESS = 0,RECT,IN,CIRCULAR,LEAST_SQR,ONERROR = NO,$
                AUTO MOVE = NO,DISTANCE = 0,RMEAS = None,None,None,$
                READ POS = NO,FIND HOLE = NO,REMEASURE = NO,$
                NUMHITS = 5,INIT = 0,PERM = 0,SPACER = 0,PITCH = 0,$
                START ANG = 0,END ANG = 0,DEPTH = 0.02,$
                ANGLE VEC = 1,0,0
                ASSIGN/V1 = CIR1.DIAM/2
    F1         =GENERIC/LINE,DEPENDENT,RECT,$
                NOM/XYZ,0,0,0,$
                MEAS/XYZ,CIR1.X,CIR1.Y,CIR1.Z,$
                NOM/IJK,1,0,0,$
                MEAS/IJK,1,0,0,$
                DISTANCE/0.375,V1
    Contura Calypso 5.4
                  TARG/0,0,0,0,0,1
                  ANGLE VEC = 1,0,0
                  NOM/XYZ,[COLOR="Blue"][/COLOR][COLOR="Blue"]CIR1.TX,CIR1.TY,CIR1.TZ[/COLOR],$
                  NOM/IJK,1,0,0,$
                  MEAS/IJK,1,0,0,$
                  DISTANCE/0.375,V1
      Sorry (again)! I just edit my thread, I already know how to do this but not know how to as described in edited part of my thread.
                    TARG/0,0,0,0,0,1
                    ANGLE VEC = 1,0,0
                    NOM/XYZ,0,0,0,$
                    MEAS/XYZ,[COLOR="Red"]CIR1.X+CIR1.R[/COLOR],CIR1.Y,CIR1.Z,$
                    NOM/IJK,1,0,0,$
                    MEAS/IJK,1,0,0,$
                    DISTANCE/0.375,V1
        Could this work?
        Not 100% sure regarding the syntax for the CIR1.R part, could be CIR1.R.MEAS or CIR1.MEAS.R...
        You can look it up by going into the 'Assignment' dialog, though.
        PC-DMIS CAD++ 2o19 R1 SP11
          Originally posted by vpt.se View Post
                      TARG/0,0,0,0,0,1
                      ANGLE VEC = 1,0,0
                      NOM/XYZ,[COLOR="Blue"][COLOR="blue"][COLOR="blue"][SIZE="4"]CIR1.TX,CIR1.TY,CIR1.TZ[/SIZE][/COLOR][/COLOR][/COLOR],$
                      NOM/IJK,1,0,0,$
                      MEAS/IJK,1,0,0,$
                      DISTANCE/0.375,V1
          Could this work?
          No. That's the problem I'm having is to learn PCDMIS VB syntax, I tried different syntax one of them matches yours.
          By the way, I always enter the Nominal value in generic features, is this necessary or is it over kill?
            Check the syntax via 'Assignments', choose the CIR1 in the assignment dialog (features), then properties. In there you'll find DIAM - insert that line so you get the entire syntax in the textbox, then simply remove the DIAM portion and replace it with R (as in radius). The radius property isn't displayed but it exists.
              Use the expression bulider (F2) that will give you the proper syntax and yes .R will give you the measured value.
              By adding the theo values you can dimension the feature and show deviation from nominal.
              This however wil give you some wild deviations:
                          NOM/XYZ,CIR1.TX,CIR1.TY,CIR1.TZ,$
                          MEAS/XYZ,CIR1.X+CIR1.R,CIR1.Y,CIR1.Z,$
                          NOM/IJK,1,0,0,$
                          MEAS/IJK,1,0,0,$
                          DISTANCE/0.375,V1
              Not sure what you are doing but it sould probably be this:
                          NOM/XYZ,CIR1.TX[COLOR="Blue"]+CIR1.TR[/COLOR],CIR1.TY,CIR1.TZ,$
                          NOM/IJK,1,0,0,$
                          MEAS/IJK,1,0,0,$
                          DISTANCE/0.375,V1
              sigpic 1.61803399Δ
                Thanks sles, for providing the correct syntax!
                              NOM/IJK,1,0,0,$
                              MEAS/IJK,1,0,0,$
                              DISTANCE/0.375,V1
                              NOM/IJK,1,0,0,$
                              MEAS/IJK,1,0,0,$
                              DISTANCE/0.375,V1
                  Can't tell how much I appreciate your help. It's exactly what I need.
                  Thank you all.
