Customer wants a plain text RTF file. When I print a RTF in reports it is 50X bigger than when I print the edit window in RTF. I actually need the report window but tryed the edit for comparision. It is also heavily formatted and takes a while to open. Anyway I can print a barebones report window in RTF the way 3.7 used to???
Kahuna RTF????
go to Insert/ report command/ Legacy Reportsigpichttp://npmichaels.com/ (My sons book)
THANKS (CAD IS ALWAYS MASTER)
Yeah, AIN'T THAT NICE!
There is a setting in the settings editor, search for AMY I think, there is ONLY one, and change the setting. I think the only options are 0 and 1. Dang, I JUST did this on my PC that has V4.2 on it, but the main PC is running Pcdmis and I would have to switch the dongle from one to the other to get it.
It will STILL be a bigger report than it used to be, but it will be the plain RTF file again.sigpic
Originally posted by SABarber View PostDoNotUseAmyuniRTF - a setting of 2 would be good. You can also set the report to "default.rtp" which is just text output.
I don't know who this AMY person is, but, well, YOU know what I think of her!
Amy Uni. Maybe I'll do a Zaba Search for her to find out where she lives.....sigpic
Originally posted by Matthew D. Hoedeman View PostWHAT HE SAID! I think if you search for AMY in the editor, this is the ONLY setting that will come up.
Anyway... PCD settings aside, set up a text-only print driver and set it to "print to file". Then when you want a text only printout file, sans markup characters, switch printers and run. You are prompted for a file name when it runs.
Originally posted by SABarber View PostDoNotUseAmyuniRTF (found under Printing) - a setting of 2 would be good. You can also set the report to "default.rtp" which is just text output.sigpicThanks a Millionth
Also, note that this is discussed in the "Viewing a Legacy Text Only Report" topic and in the "Output to a File" topic in the help file.Jared Hess - Techwriter @ WAI
by quicklearnerHi,
I need help to solve the following.
I run PC DMIS 4.2.or reporting I use textonly.I saved all files in Rich format.After running...-
06-25-2010, 02:04 PM -
by johnnyrocketHi all...
Is there any way to have the .rtf files from version 4.1 save into the same type of .rtf format as version 3.7?? In other words...-
12-06-2006, 12:51 PM -
by vajncHi all
I have a problem when printing/saving CMM measurement report in .rtf file.
The document created when report is saved...-
06-03-2015, 05:33 AM -
by AuRulesI have 2 attached .jpgs one showing my print out inside PCDMIS and one showing when I save it to a file. The one inside PCDMIS seems to fit the paper...
09-15-2015, 03:45 PM -
by BayazMy company prefers to have reports in the default text only RTF format. Suddenly when we try to report out as an RTF the inspection report is blank but...
08-04-2016, 11:44 AM -
