Alignment critics needed
  • Alignment critics needed
    Please critique this alignment. I have a thick skin so don't hold back.
    If someone can point me to the help file for attachments I'd like to upload some script but can't figure it out. The attachment function never seems to get the files.
    Hopefully this quick cut 'n' paste will get some feedback.
    Cheers
    DCC_ALIGN1 =ALIGNMENT/START,RECALL:A1,LIST=YES
    ALIGNMENT/TRANS,XAXIS,PNT1
    ALIGNMENT/TRANS,YAXIS,PNT1
    ALIGNMENT/TRANS,ZAXIS,PNT1
    ALIGNMENT/LEVEL,YPLUS,LIN3
    ALIGNMENT/TRANS,ZAXIS,LIN3
    ALIGNMENT/ROTATE,YPLUS,TO,LIN3,ABOUT,ZPLUS
    ALIGNMENT/LEVEL,XPLUS,LIN2
    ALIGNMENT/END
    Your alignment, as a single alignment, should be done, LEVEL, ROTATE, then ORIGINS.
    You are re-setting all the axis after you set them to the point.
    Level to a feature, then rotate to a feature, THEN set the origins.
      Yeah, what he said. Also keep in mind that the alignment will be the last thing you do. IE, yuo cannot put the Z axis on two seperate features, the alignment will keep the last one you do.
      HTH
