Finding all OUTTOLs for legacy dimensions is easy and the widely distributed OUTTOL.BAS, especially with the CRAIGER modifications
, is very easy to use. However, it does NOT work for the XactMeasure GD&T. This was confirmed by Hexagon.
Below is a simple piece of code that checks for both the Legacy AND XactMeasure GD&T for OUTTOL conditions. It even checks the XactMeasure in the second tier in case of composite FCF's.
As a debug tool, I decided to store all OUTTOLS in a file called COMMANDS.TXT. This file has no value, other then that it helps to understand how this script works.
There is still the issue of profile. Profile is not properly evaluated by PC-DMIS. This has been reported numerous times but Hexagon informed me that they believe they do it right. If you want to correctly evaluate profile you will have to add your own code. I may do that in the future, if this becomes a real issue for me.
Jan.
Jan.
Sub Main() 'This *.bas is a simple, modified version of Craigs modified outtol.bas (whose original author nobody seems To know). 'Jan. 'What it does: 'It takes all Dimensions that have an ID that starts With CD (For Critical dimension), regardless whether they are legacy Or XactMeasure. 'Then it will look whether this dimension is out of tolerance Or Not. ' If it is OutTol, it will increase PC-DMIS variable "NUMBEROUTTOL". ' This works also For the second tier of the FCF For the XactMeasure GD&T. ' One known problem: this does Not address the XactMeasure Profile tolerance issue (PC-DMIS does Not evaluate that properly). To correct this ' a lot more code will need To be developed. ' For debug purposes, the results are stored In a file called COMMANDS.TXT. Dim objApp As Object Set objApp = CreateObject("PCDLRN.Application") Dim objPart As Object Set objPart = objApp.ActivePartProgram Dim objCmds As Object Set objCmds = objPart.Commands Dim objCmd As Object Dim objDimCmd As Object Dim dblOutTol As Long dblOutTol = 0 Dim objOutTol As Object Set objOutTol = objPart.GetVariableValue("NUMBEROUTTOL") 'number of outtols found Open "C:\PCDMISW\COMMANDS.TXT" For Output As #3 Dim objCmdIDName As String Dim prevIDName As String Dim objCmdDeviation As Double Dim objCmdOuttol As Double For Each objCmd In objCmds objCmdIDName=objCmd.ID 'capture the ID Name of the command that is being looked at. If objCmdIDName="" Then 'Make sure that commands always have a Name. objCmdIDName=prevIDName End If prevIDName= objCmdIDName 'save the old Name just In Case the Next one is "" 'First Step: hunt For all the dimensions that start With CD For Critical Dimension. If left(objCmdIDName,2)="CD" Then 'If you find a cmd that starts With CD, Then there are 2 posibilities. 'Second Step: first possibility: hunt For legacy dimensions If objCmd.IsDimension Then Set objDimCmd=objCmd.DimensionCommand If objDimCmd.OutTol<>0 Then dblOutTol=dblOutTol+1 End If 'objDimCmd.OutTol<>0 Print #3, "***LEGACY***" & objCmdIDName & "***" Print #3, "OUTTOL number: " & objDimCmd.OutTol Print #3, "Number out of tolerance: " & dblOutTol Print #3, "" End If 'objCmd.IsDimension 'Third Step: second possibility: hunt For XactMeasure GD&T dimensions If objCmd.Type=184 Then 'this seems To be the way To find an XactMeasure GD&T Call. If objCmd.gettext(LINE1_OUTTOL,1)<>"" Then 'look In Line 1 For an OUTTOL If objCmd.gettext(LINE1_OUTTOL,1)<>0 Then 'If there is an OUTTOL In Line 1, is it Not zero? dblOutTol=dblOutTol+1 End If 'objCmd.gettext(LINE1_OUTTOL,1)<>0 Print #3, "***XactMeasure Line1***" & objCmdIDName & "***" Print #3, "OUTTOL number: " & objCmd.gettext(LINE1_OUTTOL,1) Print #3, "Number out of tolerance: " & dblOutTol Print #3, "" End If 'objCmd.gettext(LINE1_OUTTOL,1)<>"" If objCmd.gettext(LINE2_OUTTOL,1)<>"" Then 'look In Line 2 For an OUTTOL If objCmd.gettext(LINE2_OUTTOL,1)<>0 Then 'If there is an OUTTOL In Line 2, is it Not zero? dblOutTol=dblOutTol+1 End If 'objCmd.gettext(LINE1_OUTTOL,1)<>0 Print #3, "***XactMeasure Line2***" & objCmdIDName & "***" Print #3, "OUTTOL number: " & objCmd.gettext(LINE2_OUTTOL,1) Print #3, "Number out of tolerance: " & dblOutTol Print #3, "" End If 'objCmd.gettext(LINE2_OUTTOL,1)<>"" If objCmd.gettext(LINE3_OUTTOL,1)<>"" Then 'look In Line 3 For an OUTTOL If objCmd.gettext(LINE3_OUTTOL,1)<>0 Then 'If there is an OUTTOL In Line 3, is it Not zero? dblOutTol=dblOutTol+1 End If 'objCmd.gettext(LINE3_OUTTOL,1)<>0 Print #3, "***XactMeasure Line3***" & objCmdIDName & "***" Print #3, "OUTTOL number: " & objCmd.gettext(LINE3_OUTTOL,1) Print #3, "Number out of tolerance: " & dblOutTol Print #3, "" End If 'objCmd.gettext(LINE3_OUTTOL,1)<>"" End If 'objCmd.Type=184 End If 'left(objCmdIDName,2)="CD" Next objCmd Close #3 objOutTol.DoubleValue=dblOutTol objPart.SetVariableValue "NUMBEROUTTOL",objOutTol End Sub 'Jan
