Tip object
  • Tip object
    Hi,
    I am trying to get A angle of tip for script.
    From help:
    "Tip.A
    Returns the A angle of the tip. Read-only Double."
    I have no clue how to retrieve data. How I can A angle of current tip?
    Here you go:
    LOADPROBE/LSPX1_3X50
    TIP/T1A-90B0, SHANKIJK=0, -1, 0, ANGLE=0
    ASSIGN/A_ANGLE=PROBEDATA("A")
    ASSIGN/B_ANGLE=PROBEDATA("B")
    PcDmis 2015.1 SP10 CAD++
    Global 7-10-7 DC800S
    • Darius11
      Darius11 commented
      This is for pc dmis itself. At the moment I do have:
      [ If Cmd.Type = SET_ACTIVE_TIP Then
      ProbeAngle1 = right(left(Cmd.GetText (ID, 0),instr(1,Cmd.GetText (ID, 0),"B")-1),(len(left(Cmd.GetText (ID, 0),instr(1,Cmd.GetText (ID, 0),"B")-1))-instr(1,left(Cmd.GetText (ID, 0),instr(1,Cmd.GetText (ID, 0),"B")-1),"A")))
      It doing job but if I could replace this "right(left(Cmd.GetText (ID, 0),instr(1,Cmd.GetText (ID, 0),"B")-1),(len(left(Cmd.GetText (ID, 0),instr(1,Cmd.GetText (ID, 0),"B")-1))-instr(1,left(Cmd.GetText (ID, 0),instr(1,Cmd.GetText (ID, 0),"B")-1),"A")))" by one command it would be easier to reed.
    Other thing what I can't find out is how to use MOVE_CLEARPOINT .Script should check if before every "LOADPROBE/B" command is command "MOVE/CLEARPOINT". Basically should be " If Cmd.Type = SET_ACTIVE_TIP " and previous command wasn't "MOVE/CLEARPOINT" then MSGBOX... . I did try things like "if cmd.Type = MOVE_CLEARPOINT Then "...... but no positive result was achieved. Any ideas?
    • davehocum
      davehocum commented
      Replace MOVE_CLEARPOINT with 163.
    • Darius11
      Darius11 commented
      Thanks, it did work.
    • davehocum
      davehocum commented
      No problem
    Not at work but iirc loadprobe is not type Set_active_tip? You may need to back up another step.
      Seems to be:
      MOVE/CLEARPOINT = MOVE_CLEARPOINT (163)
      LOADPROBE/ * = GET_PROBE_DATA ( 61)
      TIP/* = SET_ACTIVE_TIP (60)
      Activetip has an .Angle property, but that could be for B. Otherwise you can use the Probe object to find tip info, but I wouldn´t recommend that. Better to do what you do already. I'd put it in a function so it doesnt mess up the code so much.
      • Darius11
        Darius11 commented
        Thanks. I didn't manage to get A angle in any other way than my so I will stick to my way.
        Could you be more specific what do you mean by "put it in a function". If that isn't that what i have done, then it is outside of my experience.
      I have a similar function for what is likely a similar purpose...
      In VBA:
      Function NegativeTip(name As String) As Boolean
      Dim Temp() As String
      Dim Angle As Integer
      Temp = Split(name, "A")
      Temp = Split(Temp(1), "B")
      Angle = CInt(Temp(0))
      If Angle <= 0 Then
      NegativeTip = True
      Else
      NegativeTip = False
      End If
      End Function
      • Darius11
        Darius11 commented
        Thanks, nice piece.
        I do understand logic of this function and it looks better than my piece of code. From other hand I do not use any single function in my scripts and I didn't have any working function and that is probably because when I started programming I didn't have any success on creating functions. At this time I'm nearly running out of ideas and when I will run out of ideas then I will start optimisation of scripts then I will try functions again.
      • LostL
        LostL commented
        Paste this into your module and try calling MsgBox AngleA(Cmd.GetText (ID, 0)) . You REALLY should use functions in anything that isn´t trivial. It´s not difficult either, if you´ve failed it´s just some minor syntax error.
        Function AngleA(Name As String) As Integer
        Temp = Split(Name, "A")
        AngleA = CInt(Temp(0))
        End Function
      Well... tried, tried but.... I can't understand what exactly I can't understand. I done copy and paste to my script "Sub Main" but I didn't overcome error.
      Could you please to do little script which scan CMM program and display angles A of tip? Maybe it could help me understand where is problem.
      I'm receiving message with syntax error but I can't see any error. I'm using pc dmis 15.1, could it be problem for run of functions?
