Very new too coding.
  • Very new too coding.
    Hey all, I have been trying out some if/ statements and what not. The hardest part is knowing the syntax to use. Is there a place I can go to find working syntax? Also, I wanted to see if this code would work the way i wanted it too. so here is the code-->
    MODE/DCC
    LOADPROBE/PRB2
    C1 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    OPERATOR:
    C2 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    REASON FOR RUN:
    C3 =COMMENT/INPUT,NO,FULL SCREEN=NO,
    SAMPLE #:
    C4 =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO,
    HAS PART MOVED SINCE LAST RUN?
    IF/C4.INPUT=="YES"
    END_IF/
    IF/C4.INPUT=="NO"
    RDPNT =FEAT/POINT,CARTESIAN
    THEO/<0,0,0>,<0,0,1>
    ACTL/<0,0,0>,<0,0,1>
    READPOINT/
    IF/RDPNT.Z<100
    MOVE/INCREMENT,<0,0,200>
    END_IF/
    MOVE/POINT,NORMAL,<0,0,100>
    MOVE/POINT,NORMAL,<0,0,0>
    GOTO/READPNT
    END_IF/
    PLACE PROBE IN THE STARTING POSITION. SEE CAD FOR REFERENCE.
    READPNT =FEAT/POINT,CARTESIAN
    READPOINT/
    RDPNTALIGNX =ALIGNMENT/START,RECALL:STARTUP,LIST=YES
    ALIGNMENT/TRANS,XAXIS,READPNT
    ALIGNMENT/TRANS,YAXIS,READPNT
    ALIGNMENT/TRANS,ZAXIS,READPNT
    ALIGNMENT/END
    CIR1 =FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
    THEO/<0,0,0>,<0,0,1>,9
    ACTL/<0,0,0>,<0,0,1>,9
    TARG/<0,0,0>,<0,0,1>
    START ANG=0,END ANG=360
    ANGLE VEC=<1,0,0>
    DIRECTION=CCW
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    NUMHITS=7,DEPTH=2,PITCH=0
    SAMPLE METHOD=SAMPLE_HITS
    SAMPLE HITS=0,SPACER=0
    AVOIDANCE MOVE=NO,DISTANCE=10
    SHOW HITS=NO
    I would like the program to be able to run on its own with no operator touching the jog box as long as the part has ran once already. Would this work the way I am wanting it too? Is there a better code sample for doing this that I haven't seen?
    Thanks in advance.
    On an if/then statement, if you're only checking for one answer, you don't have to do anything for the other answer. In your code you have
    IF/C4.INPUT=="YES"
    END_IF/
    In plain language, evaluating for both conditions when you only want one looks something like this
    If the door is open (YES), close it. If the door is not open (NO), don't close it.
    I could have stopped after the first sentence, the second sentence must be the case if the first isn't true, and I'm not doing anything in the second case, so I don't need it documented. It's a minor thing, but...
    Another thing -
    IF/RDPNT.Z<100
    END_IF/
    Good plan, but what if the Z axis is only 190 away from the end of travel? You throw an error and the program stops execution. You want to make sure the probe is a certain height and, IF it isn't, move it straight up without an X or Y move. There are two ways to do this that are easier.
    Since you want to get to 100, try either example below
    {code]MOVE/POINT,NORMAL,<,,100>[/code]
    or
    [code]
    PNT1 =FEAT/POINT,CARTESIAN
    THEO/<0.1339,-2.845,0.7591>,<-1,0,0>
    ACTL/<0.1339,-2.845,0.7591>,<-1,0,0>
    READPOINT/
    MOVE/POINT,NORMAL,<PNT1.X,PNT1.Y,100>
    ]code]
    • ThePudds
      ThePudds commented
      Makes sense. If/C4.input=="yes" has been taken out. Thanks for the info.
    So how does this look?
    [code]C4 =COMMENT/YESNO,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO,
    IF/C4.INPUT=="NO"
    READPOINT/
    IF/RDPNT.Z<100
    MOVE/POINT,NORMAL,<RDPNT.X,RDPNT.Y,100>
    END_IF/
    IF/RDPNT.Z>100
    MOVE/POINT,NORMAL,<0,0,50>
    END_IF/
    GOTO/READPNT
    END_IF/
    READPOINT/[code]
