This is probably very simple to those of you who need, or find the need to use code on a regular basis...but I am very rusty and need some guidance.
So, I have 2 dims, X and Z and a tolerance to each of those....I have created assignments to each deviation, so far so good. I have created 2 labels, "restart", and "continue"....
Ok, so what I am looking to do....after the measurement, I want the code to say, yes, this is in tolerance, jump to the "continue" label, if its not in tolerance, I want an operator prompt to pop up and say, "re adjust and try again" and obviously jumping back to the "restart label as well.....
I know what I need to do, but the syntax gets me every time....
Here is what I have so far...
RESTART =LABEL/
_B_ LOCATOR=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<621.234,802.112,688.115>,<0,-1,0>,10
ACTL/<621.262,802.161,688.074>,<0,-1,0>,10.085
TARG/<621.234,802.112,688.115>,<0,-1,0>
START ANG=0,END ANG=360
ANGLE VEC=<-1,0,0>
DIRECTION=CCW
SHOW FEATURE PARAMETERS=NO
SHOW CONTACT PARAMETERS=YES
NUMHITS=4,DEPTH=1,PITCH=0
SAMPLE METHOD=SAMPLE_HITS
SAMPLE HITS=1,SPACER=2
AVOIDANCE MOVE=NO,DISTANCE=10
SHOW HITS=NO
DIM D4= LOCATION OF CIRCLE _B_ LOCATOR
X 621.234 0.075 0.075 621.262 0.028 0.000
Z 688.115 0.075 0.075 688.074 -0.041 0.000
END OF DIMENSION D4
MOVE/CLEARPLANE
_C_ LOCATOR=FEAT/CONTACT/CIRCLE/DEFAULT,CARTESIAN,IN,LEAST_SQR
THEO/<1428.069,605.06,1100.772>,<0,-1,0>,8
ACTL/<1428.057,605.06,1100.703>,<0,-1,0>,8.087
TARG/<1428.069,605.06,1100.772>,<0,-1,0>
ANGLE VEC=<1,0,0>
DIRECTION=CCW
NUMHITS=4,DEPTH=0,PITCH=0
SAMPLE HITS=0,SPACER=3
AVOIDANCE MOVE=AFTER,DISTANCE=5
SHOW HITS=NO
DIM D5= LOCATION OF CIRCLE _C_ LOCATOR
X 1428.069 0.075 0.075 1428.057 -0.012 0.000
Z 1100.772 0.075 0.075 1100.703 -0.069 0.000
END OF DIMENSION D5
ASSIGN/V1=D4.X.DEV
ASSIGN/V2=D4.Z.DEV
ASSIGN/V3=D5.X.DEV
ASSIGN/V4=D5.Z.DEV
ASSIGN/V5=0
CONTINUE =LABEL/
RESTART =LABEL/
ANGLE VEC=<-1,0,0>
DIRECTION=CCW
SHOW HITS=NO
END OF DIMENSION D4
MOVE/CLEARPLANE
ANGLE VEC=<1,0,0>
DIRECTION=CCW
SHOW HITS=NO
END OF DIMENSION D5
ASSIGN/V1=D4.X.DEV
ASSIGN/V2=D4.Z.DEV
ASSIGN/V3=D5.X.DEV
ASSIGN/V4=D5.Z.DEV
ASSIGN/V5=0
CONTINUE =LABEL/
