Move Clear Point.bas
  • Move Clear Point.bas
    I use this Basic Cypress Enable Script example to add, execute and remove the Move Clear Point using a created icon place in the drop down Menu Bar list.
    Dim DmisApp As Object
    Dim DmisPart As Object
    Dim DmisCommands As Object
    Dim DmisCommand As Object
    Dim Msg, Style, myTitle, Help, Ctxt, Response, MyString
    Sub ClearPoint
           Msg = "Executing Move Clear Point? "& chr(10) & chr(10) & "Validate Probe path is clear" ' Define message.
           Style = vbYes + vbCritical '+ vbDefaultButton1 'Define buttons.
           Style = 1 + 16 + 0 ' Define buttons.
           myTitle = "Add Move Clear Point" 'Define Title
           Help = "DEMO.HLP" ' Define Help file.
           Ctxt = 1000 ' Define topic context.
           'Display message.
           Response = MsgBox(Msg, Style, myTitle, Help, Ctxt)
           'MsgBox Response
        If Response = 1 Then 'vbNo Then 'User chose Yes.
           MyString = 1 ' Perform some action.
           Set DmisCommand = DmisCommands.CurrentCommand
           Set DmisCommand = DmisCommands.Add(163, True) 'MOVE_CLEARPOINT
           DmisCommand.ReDraw
           retval = dmiscommand.execute
           retval = dmiscommand.remove
           MsgBox "Executing Move Clear Point Complete"
           DmisCommand.ReDraw
       Else ' User chose No.
          MyString = 2 ' Perform some action.
          MsgBox "Executing Move Clear Point has been Canceled"
       End If
    End Sub
    Sub Main
           Set DmisApp = CreateObject("PCDLRN.Application")
           Set DmisPart = DmisApp.ActivePartProgram
           Set DmisCommands = DmisPart.Commands
           CommandCount = DmisCommands.Count
           Set DmisCommand = DmisCommands.Item(CommandCount)
           DmisCommands.InsertionPointAfter DmisCommand
           Msg = "Do you want to continue Executing Move Clear Point? " ' Define message.
           Style = vbYes + vbCritical '+ vbDefaultButton1 ' Define buttons.
           Style = 4 + 32 + 0 ' Define buttons.
           myTitle = "Execute Added Move Clear Point" ' Define Title
           'Display message.
          'MsgBox Response
       If Response = 6 Then 'vbNo Then ' User chose Yes.
          MyString = 6 ' Perform some action.
          ClearPoint
      Else  'User chose No.
          MyString = 7 ' Perform some action.
      End If
         Set DmisApp = Nothing
         Set DmisPart = Nothing
         Set DmisCommand = Nothing
         Set DmisCommands = Nothing
    End Sub
