Having some trouble figuring this out. I have a .txt file with a number 1-9 in it and I want PcDmis to read the file, read the number and use it an an assignment V2. If the number is greater than 5 go to a operator comment and if its not true, go to another operator comment.
The code works but my if_goto isn't working. Also when I highlight over the variables, my cursor shows 0 (zero). So if the value is 6 it should say display the true operator comment and if its 4 it should display the not true operator comment but it always says true even though the number is less than 5.
ASSIGN/DATA1="C:\USERS\RENEGADE PRECISION\DESKTOP\TEST REPORTS\TEST.TXT" FPTR =FILE/OPEN,DATA1,READ V1 =FILE/READ_BLOCK,FPTR,2 FILE/CLOSE,FPTR,KEEP ASSIGN/V2=V1 COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, "value is "+V2[COLOR=#0000FF]<------op comment pops up with the correct value in the .txt file. I enter the value and save it manually in the file so this part works.[/COLOR] IF_GOTO/V2>5,GOTO = TRUE TRUE =LABEL/ COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, true GOTO/END NOT_TRUE =LABEL/ COMMENT/OPER,NO,FULL SCREEN=NO,AUTO-CONTINUE=NO, not true END =LABEL/
