how can i reset mesured values to nominal with code
Reset
by mdleeI have a program where I need to use the measured values from one part as the master for another part. Is there an easy way to swap the Nominal (Theo)...
09-10-2010, 07:39 AM -
Has anyone ever correlated Mpe values to VA results? I would like to create a spreadsheet that would covert Mpe values to VA values & vice versa....
04-01-2008, 12:16 PM -
by DaSaloAnyone know how to reset the measured values in a FreeForm scan back to the theoreticals? This type of scan seems to behave quite differently from the...
05-12-2013, 10:37 AM -
by MrBloondyHi guys, is there any way to set the nominal values of all features related with their real values that i have measured. In order to use a standard part/...
05-30-2016, 06:41 AM -
by BIGWIG7Is there a way to reset the Nominals after the program has run?
Forgot to save a master version and I would like to reset a run program...-
08-18-2015, 09:38 AM -
