I was working on this script to help quickly insert comments into a program for reporting purposes and thought I would share with people to get feedback and maybe answer a couple of questions.
The way the script works is it asks the user to enter the number of comments to insert with an input box, then it adds numbered (001,002,etc) $$ comments based on the number entered.
Everything works well for me when I use Excel VBA, but I get errors when using the PC-Dmis basic editor. I'm aware there are differences between the two, but I'm not really sure what the key differences are. So if anyone has input on that or how to fix my script to work INSIDE the pc-dmis basic editor, I would greatly appreciate it.
Below is the working code for Excel VBA:
Below is sample code for reference to change to a REPT comment
Sub QuickPCDComment() Dim DmisApp As Object Dim DmisPart As Object Dim DmisCommands As Object Dim DmisCommand As Object Set DmisApp = CreateObject("PCDLRN.Application") Set DmisPart = DmisApp.ActivePartProgram Set DmisCommands = DmisPart.Commands Dim inputAnswer As Integer inputAnswer = InputBox("Enter number of comments to insert (zero ends loop):") '''Displays PC-DMIS Application DmisApp.Visible = True DmisApp.SetActive DmisApp.Maximize If inputAnswer < 10 Then '''Input entered below 10 Dim counter Dim commentNumber As String counter = 0 commentNumber = 1 Do While counter < inputAnswer Set DmisCommand = DmisCommands.Add(SET_COMMENT, True) DmisCommand.Marked = True retval = DmisCommand.PutText("", ID, 0) retval = DmisCommand.SetToggleString(4, COMMENT_TYPE, 0) retval = DmisCommand.PutText("00" + commentNumber, COMMENT_FIELD, 1) retval = DmisCommand.SetToggleString(1, OUTPUT_TYPE, 0) counter = counter + 1 commentNumber = commentNumber + 1 Loop Else '''Input entered above 10 Dim counter2 Dim commentNumber2 As String counter2 = 0 commentNumber2 = 1 '''Comments # 1-9 Do While counter2 < 9 Set DmisCommand = DmisCommands.Add(SET_COMMENT, True) DmisCommand.Marked = True retval = DmisCommand.PutText("", ID, 0) retval = DmisCommand.SetToggleString(4, COMMENT_TYPE, 0) retval = DmisCommand.PutText("00" + commentNumber2, COMMENT_FIELD, 1) retval = DmisCommand.SetToggleString(1, OUTPUT_TYPE, 0) counter2 = counter2 + 1 commentNumber2 = commentNumber2 + 1 Loop '''Comments # 10-inputAnswer Do While counter2 < inputAnswer Set DmisCommand = DmisCommands.Add(SET_COMMENT, True) DmisCommand.Marked = True retval = DmisCommand.PutText("", ID, 0) retval = DmisCommand.SetToggleString(4, COMMENT_TYPE, 0) retval = DmisCommand.PutText("0" + commentNumber2, COMMENT_FIELD, 1) retval = DmisCommand.SetToggleString(1, OUTPUT_TYPE, 0) counter2 = counter2 + 1 commentNumber2 = commentNumber2 + 1 Loop End If End Sub
Set DmisCommand = DmisCommands.Add(SET_COMMENT, TRUE) DmisCommand.Marked = TRUE ' Set Id = retval = DmisCommand.PutText ("", ID, 0) ' Set Comment Type = REPT retval = DmisCommand.SetToggleString (2, COMMENT_TYPE, 0) ' Set Comment Item 1 = Please Edit Comment Text! retval = DmisCommand.PutText ("Please Edit Comment Text!", COMMENT_FIELD, 1)
