Tracefield date added to report header?
  • Tracefield date added to report header?
    Is there a way to put a tracefield in to update the REV Number report header without having to change the label template?Capture.JPG
    I.E -> Tracefield at start for a PO Number that is auto entered in the Report template.
    Thanks.
    Hi,
    One of possibilities is add tracefield to Pc-dmis program, as example:
    TRACEFIELD/NO_DISPLAY,LIMIT=15 ; Drawing rev. : 7
    Then modify label, add to REV NUMBER field:
    =tracefield(1)
    (1) is number of tracefield. If you have only one tracefield in a program then should be 1, if you have 4 tracefields in a program and tracefield with revision is 3-th, then should be (3).
      No, you can't change the templates without changing the templates. What's your problem with changing the label template - write permissions? Talk to your boss, if you can't do your job because of restrictions they need to be revised.
        a little more here as well
        https://www.pcdmisforum.com/forum/pc...ion-automation
