Trying to access the my Cad model in the Graphics Display Window using a PC-DMIS basic script. Getting a "Missing parameter(s)" error message. Here's what I have with the error being generated on the last line seen below;
Sub GetProjectPointData()
Dim App As Object
Dim Part As Object
Dim Cmds As Object
Dim GWindow As Object
Dim CadWin As Object
Set App = CreateObject("PCDLRN.Application")
Set Part = App.ActivePartProgram
Set Cmds = Part.Commands
Set GWindow = Part.CadWindows
Set CadWin = GWindow.Item(1)
Dim CADMod As CadModel
Set CADMod = Part.CadModel
Dim RetVal As Boolean
Dim XT, YT, ZT, DIRX, DIRY, DIRZ, PX, PY, PZ, PDIRX, PDIRY, PDIRZ As Double
Dim FeatureName, FID As String
CadWin.Visible = True
XT=NetData(7,1)
YT=NetData(7,2)
ZT=NetData(7,3)
CADMod.CADProjectPoint(XT, YT, ZT,7,0,0, PX, PY, PZ, PDIRX, PDIRY, PDIRZ,2)
The Function info in the help menus has 13 parameters, (as do I). Haven't tried accessing the Graphics display window from a script before and not sure if i have everything right here, but it does compile without errors, so...
If anyone that has basic script/Pcdmis knowledge about this topic, it would be much appreciated if you could take a peek at this and steer me in the right direction if there are blaring issues seen at first glance.
Dim App As Object
Dim Part As Object
Dim Cmds As Object
XT=NetData(7,1)
YT=NetData(7,2)
ZT=NetData(7,3)
