Next question, anyone seen any way to identify if the remeasure toggle is on or off?
Remeasure toggle...
In the Edit Window, you can (if Show Feature Parameters is set to YES) check the RMEAS=(etc etc) section of code within a feature.
Edit: the above is incorrect
Are you trying to do this for every program, or just look at a specific feature and check?Last edited by InspectorJester; 04-10-2019, 08:15 AM.
To find the answer you create a small part program with one circle with remeasure=NO, and one with remeasure=YES, export the program as BASIC.
By comparing what PC-DMIS generated you will find that it is the toggle RMEAS_TYPE (I wonder what Relative Measure is called internally?)!
Code:' Set Re-Measure = NO retval = DmisCommand.SetToggleString (1, RMEAS_TYPE, 0) ' Set Re-Measure = YES retval = DmisCommand.SetToggleString (2, RMEAS_TYPE, 0)
I just had to test Relative Measure too…
Code:' Set Relative Measure Feature X = CIR1 retval = DmisCommand.PutText ("CIR1", RMEASFEATIDX, 0) ' Set Relative Measure Feature Y = CIR1 retval = DmisCommand.PutText ("CIR1", RMEASFEATIDY, 0) ' Set Relative Measure Feature Z = CIR1 retval = DmisCommand.PutText ("CIR1", RMEASFEATIDZ, 0)
- 4 likes
good day all !
here is a NOOB question.
how do I disable feature names appearing when I hover mouse in graphix window? It keeps getting...-
01-26-2013, 06:08 AM -
by mattfurtawOkay GURU's. I am looking for the easiest way to have the operator select multiple items at the beginning of the program in order to inspect certain features....
06-10-2014, 08:31 AM -
by scharschHi,
Just wondering if following can be done:
While in either Summary or Command mode when you have a feature highligted in the edit window...-
05-13-2008, 08:37 AM -
I am checking a part using lots of points.
When I finished measuring my part graphic screen is overwhelmed with ID lables. I was wondering if there...-
12-16-2008, 11:49 AM -
by RmhowardDoes anyone know of a setting that will allow the program to zoom in on the feature automatically during program execution?
or is there...-
Channel: PC-DMIS Portable
08-28-2014, 01:29 PM -
