Is there a way to access a PC-DMIS array variable from PC-DMIS Basic?
  • Is there a way to access a PC-DMIS array variable from PC-DMIS Basic?
    Is there a way to access a PC-DMIS array variable from PC-DMIS Basic? The Help for GetVariableValue() doesn't mention arrays and indices.
    Is that helps ? (from PCDBASIC 3.6)
    Variable.GetArrayUpperBound
    Syntax
    Return Value=expression.GetArrayUpperBound
    Return Value: This returns the upper bound if the variable is an array. Otherwise it
    returns zero.
    expression: required expression for object type Variable.
    Variable.GetArrayLowerBound
    Syntax
    Return Value=expression.GetArrayLowerBound
    Return Value: This returns the lower bound if the variable is an array. Otherwise it
    returns zero.
    Variable.GetArrayIndexValue
    Syntax
    Return Value=expression.GetArrayIndexValue
    Return Value: This returns the array variable at the specified index position.
    Variable.SetArrayIndexValue
    Syntax
    Return Value=expression.SetArrayIndexValue (Index, Variable)
    Return Value: This sets the array variable at the specified index position. Type
    Boolean.
    Index: Long value specifying the index
      Yes, found them in the Type Library, but still not sure how to get at them. Experimenting...
      OK, this seems to work! But GetArrayUpperBound returns the number of elements + 1, and it took a while to find the .PointValue which is necessary to get at the parts (XYZ) of the indexed value.
      Thanks!
      Sub Main
        Dim App As Object
        Set App = CreateObject ("PCDLRN.Application")
        Dim Part As Object
        Set Part = App.ActivePartProgram
        Dim Var As Object
        Dim i_var As Object
        Set Var = Part.GetVariableValue ("PT")
        MsgBox Var.GetArrayUpperBound
        Set i_var = var.getarrayindexvalue(2).PointValue
        MsgBox i_var.x
      End Sub
        You should try something like Option Base 1 at the start.
        • AndersI
          AndersI commented
          Doesn't affect anything. Probably only valid for BASIC arrays, not PC-DMIS ones.
          But maybe "Upper Bound" means "the first index that is not addressable", instead of the expected "the last index that is addressable" (or GetArrayLowerBound + <number of elements>)
          Anyway, it isn't important as long as it's consistent.
        Sub Main()
          Dim App As PCDLRN.Application
          Set App = CreateObject("PCDLRN.Application")
          Dim Part As PCDLRN.PartProgram
          Dim Var As PCDLRN.Variable
          Dim i_var As VariableArray
          Set Var = Part.GetVariableValue("PT")
          MsgBox Var.VariableType
        End Sub
        Output = 5.
        5 = VARIABLE_TYPE_ARRAY (according to the PCDLRN Object Library).
        What gives? It recognizes it as an array but can't manipulate it as one?
        PcDmis 2015.1 SP10 CAD++
        Global 7-10-7 DC800S
        • AndersI
          AndersI commented
          Every [to me] imaginable way gave "Error: Type mismatch". Doesn't mean there isn't any way to do it, but I couldn't find out how.
